Two issues with Insteon/isy
1) A few minutes after using a mini remote button, the unit will flash red several times. I think that it is looking for a legacy device. How can I clear its memory?
2) One of my Insteon switches turns on randomly. I'm thinking that there may be a hidden program that is doing this?
Thanks!  Craig, Portland OR
Solved by kzboray
Reset Mini Remotes
    Turn off Mini Remote by sliding the power switch to the right
    Press and hold the set button while sliding the power switch to the left
    Continue holding the set button until the beep stops
    Release the set button. You should hear two beeps confirming that your Mini Remote has been reset
Right click any program name, and use "Find" to see if the device is used in a program.
If it's not, there might be an odd link in the devices memory... in the device tree you could try right clicking the device a choosing "restore device" to have the ISY set the devices links again.
Thanks Mr. Bill!
