KPL Button status LED ONLY
I learned (from the Forum) how to use KPL button LED's as status indicators by putting them in scenes as controllers with the device we want "monitored".
This works great but the buttons also become controllers of the device if pressed (I don't want this).
Is there a way to use the KPL button as status ONLY? So if you inadvertantly press the button it will not do anything?
I tried a program but it did not work. I do not understand the "On 15 / Off 0 (Backlight Level)" selections either. I'm sure a description is on the board somewhere...can someone please point me in the right direction?
Status 'Garage Door A Sensor' is On
Set 'Bathroom KPL - A' On 15 / Off 0 (Backlight Level)
Set 'Bathroom KPL - A' On 0 / Off 0 (Backlight Level)
[edited] - changed my mind but couldn't delete the post :)
OK, I just set one up with a KPL as a responder only, and a SL as a controller and it worked as you advertised.
I'm not sure what was going on last time I tried doing this with my I/O lincs.
I'll have to revisit the past situation so I can get a better understanding.
Thanks for your response!
