ISY Launcher issue (InvocationTargetException)
I am having an issue running the ISY Launcher.  I can start the admin.jnlp from each ISY without issue, but if I try to use start.jnlp I get the following error.
This could be a Linux issue since I have not seen this before on my Mac.
I have tried OpenJDK1.8,11,17 with the same error.  I am running IcedTea OpenWebStart 1.5.2
[ITW-CORE][2022-05-11 20:53:28.486 MDT][INFO ][net.sourceforge.jnlp.Launcher] main completed
http://10.7.1.213/web/insteon.jar
http://10.7.1.213/WEB/CE.JAR
http://10.7.1.213/web/chart.jar
http://10.7.1.213/WEB/RXTX.jar
[ITW-CORE][2022-05-11 20:54:01.938 MDT][INFO ][net.sourceforge.jnlp.runtime.classloader.JNLPClassLoader] Application is trying to get permissions for http://10.7.1.213/web/insteon.jar, which was not added by standard way. Trying to download and verify!
[ITW-CORE][2022-05-11 20:54:01.939 MDT][INFO ][net.adoptopenjdk.icedteaweb.resources.cache.CacheImpl] isCached: CacheKey{location=http://10.7.1.213/web/insteon.jar, version=null} = false
[ITW-CORE][2022-05-11 20:54:03.087 MDT][INFO ][net.adoptopenjdk.icedteaweb.resources.cache.CacheImpl] isCached: CacheKey{location=http://10.7.1.213/web/insteon.jar, version=null} = false
java.lang.reflect.InvocationTargetException
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:566)
	at com.universaldevices.isyfinder.ISYUILoader.launch(Unknown Source)
	at com.universaldevices.isyfinder.ISYFinder.launch(Unknown Source)
	at com.universaldevices.isyfinder.ISYFinder.access$7(Unknown Source)
	at com.universaldevices.isyfinder.ISYFinder$8.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262)
	at java.desktop/javax.swing.AbstractButton.doClick(AbstractButton.java:369)
	at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1020)
	at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1064)
	at java.desktop/java.awt.Component.processMouseEvent(Component.java:6635)
	at java.desktop/javax.swing.JComponent.processMouseEvent(JComponent.java:3342)
	at java.desktop/java.awt.Component.processEvent(Component.java:6400)
	at java.desktop/java.awt.Container.processEvent(Container.java:2263)
	at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5011)
	at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321)
	at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843)
	at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918)
	at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547)
	at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488)
	at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307)
	at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772)
	at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
	at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85)
	at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95)
	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745)
	at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743)
	at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742)
	at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
	at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
	at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.IllegalAccessError: failed to access class com.universaldevices.ui.UPnPClientApplet$27 from class com.universaldevices.ui.UPnPClientApplet (com.universaldevices.ui.UPnPClientApplet$27 is in unnamed module of loader net.sourceforge.jnlp.runtime.classloader.JNLPClassLoader @94dc44; com.universaldevices.ui.UPnPClientApplet is in unnamed module of loader java.net.URLClassLoader @1aa50988)
	at com.universaldevices.ui.UPnPClientApplet.main(Unknown Source)
	at com.universaldevices.client.ui.UDClientApplet.main(Unknown Source)
	... 45 more
I have also seen this when attempting an alternate java web start:
WARNING: A terminally deprecated method in java.lang.System has been called
WARNING: System::setSecurityManager has been called by com.universaldevices.isyfinder.ISYUILoader (https://isy.universal-devices.com/launcher/isyfinder-2.2.jar)
WARNING: Please consider reporting this to the maintainers of com.universaldevices.isyfinder.ISYUILoader
WARNING: System::setSecurityManager will be removed in a future release
