stuck on step 2
installed this but step 2 udi-spa-Node server/README.md at master · UniversalDevicesInc-PG3/udi-spa-Node server · GitHub
says Add a custom variable named host containing the ip address of the bwa™ Wi-Fi Module
when I'm in the AC and go to variables I can add a state or an integer = which one am I using? and after the name host what field does the IP address go in (tried them all w no luck)
The instructions are referring to the PG3 custom parameters configuration, not ISY variables.
You enter this in configuration section of node details for the node server on the PG3 user interface.
thank you - sorry for the slow reply I just saw this because I checked back, I guess I mistakenly assumed I was automatically subscribed to notifications for content I posted (just updated my profile settings, so I am now)
I hadn't seen the node show up before on my PG3 home dashboard and as my 1st install I wasn't used to checking there.
I was able to add the host and it has connected (I can issue commands from the AC) but my set temp is showing as 102C ! would you happen to know if this can be corrected to fahrenheit? also there's only 2 pumps showing (I have 3).
