Variable +1 Using Rest Command
Is there a way to +1 to a variable using the rest command?  I use the following to set the variable to 2 and everything works fine.
/rest/vars/set/1/18/2
I'd like to be able to increment the variable using the rest command.  My current workaround is to have a program in the ISY that increments the variable ($VariableName += 1) in the "Then" part of a program and to use the rest command to run the program (/rest/programs/<programID>/runThen).  I'd like to skip the program part.
I've tried /rest/vars/set/1/18/+1 but that doesn't work.
Edited by zerop
  • 5 weeks later...
Just wanted to bump this up to the top.
Anyone?
