hart2hart Posted May 28, 2022 Posted May 28, 2022 I created a simple test program to see how Backup Node server works internally to determine if it runs in line or is launched asynchronously so the program would immediately execute the next step. I performed a Run (Then) on the program, and it only ran 1-2 seconds (was green) so the wait obviously did not occur. SecSys:DSC Alarm Test If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Backup Ligthing State / Save_Restore lighting' Backup Wait 1 minute Else - No Actions - (To add one, press 'Action') I am trying to determine if a wait is needed after the Backup and if so how long of a wait to allow before turning on the All Lights scene to avoid getting wrong light states. Backup appeared to run asynchronously (based a long or short poll showing in Node server log almost immediately followed about 11 seconds later with a storm of log events naming lots of devices with Node server logging set at debug mode short segment follows with .... used show removed information) but as a side effect it ended program execution since no Wait 1 minute occurred. If that's true and as intended, I will need backup in its own program to be run from another program that has multiple sequential steps and with a wait after it is called to allow it time to complete. Please help me understand the timing and program execution requirements so I don't make wrong assumptions. The Node server says no configuration is needed and I assume that means it knows the ISY that it is running on. How about the long and shortpoll? Do they have a function and if so what? 2022-05-28 10:08:28,756 Command udi_interface.interface DEBUG interface:send: PUBLISHING {'set': [{'key': 'customdata', 'value': {'xx xx xx x': {'name': 'Back Porch:Floods', 'value': 0}, .... }}}]} 2022-05-28 10:08:28,761 Command udi_interface DEBUG backup:query: Found node Yard:Bird Bath Bottom - Heate with type 2.57.68.0 category 2 and status 0 2022-05-28 10:08:28,762 Command udi_interface.custom DEBUG custom:__setitem__: CUSTOM: xx xx xx x = {'name': 'Yard:Bird Bath Bottom - Heate', 'value': 0} ... saving 2022-05-28 10:08:28,763 Command udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot. ... 2022-05-28 10:08:28,786 Command udi_interface INFO backup:query: Query processed 169 devices. 2022-05-28 10:08:28,787 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING customdata 2022-05-28 10:08:28,790 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING customdata 2022-05-28 10:08:28,793 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING customdata 2022-05-28 10:08:28,973 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message customdata 2022-05-28 10:08:28,975 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING customdata 2022-05-28 10:08:29,012 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata 2022-05-28 10:08:29,126 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message customdata 2022-05-28 10:08:29,127 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING customdata 2022-05-28 10:08:29,164 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata 2022-05-28 10:08:29,376 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message customdata ... Thanks
TJF1960 Posted May 28, 2022 Posted May 28, 2022 @hart2hart I believe a wait with nothing after it will not execute, it needs another command after it in order to wait.
bpwwer Posted May 28, 2022 Posted May 28, 2022 No command sent by the ISY to a node is synchronous. In this case, the ISY sends the backup command to the node server node. It does not wait for any response. The node server then queries every lighting type node for it's status. It does this one-by-one. How long it takes to complete will depend on how many devices you have and what else the ISY is busy doing. Polling is not used. It only does the queries when asked and same for the restore.
hart2hart Posted May 28, 2022 Author Posted May 28, 2022 On 5/28/2022 at 4:23 PM, TJF1960 said: @hart2hart I believe a wait with nothing after it will not execute, it needs another command after it in order to wait. Expand Never though about it but in all normal programs, I got a next command. Only for this test have I not had a next command. LOL On 5/28/2022 at 4:59 PM, bpwwer said: No command sent by the ISY to a node is synchronous. In this case, the ISY sends the backup command to the node server node. It does not wait for any response. The node server then queries every lighting type node for it's status. It does this one-by-one. How long it takes to complete will depend on how many devices you have and what else the ISY is busy doing. Polling is not used. It only does the queries when asked and same for the restore. Expand Thanks. I'll watch the Node server log to get a good estimate of how long it takes to process so I can pick a delay.
hart2hart Posted May 28, 2022 Author Posted May 28, 2022 Okay, Ive got backup running or at least it goes through steps. The problem is when I send a restore command there is error in the log. 2022-05-28 14:41:12,522 Command udi_interface DEBUG backup:restore: getting custom data to restore: {'address': 'controller', 'cmd': 'RESTORE', 'query': {}} 2022-05-28 14:41:12,523 Command udi_interface.interface ERROR interface:_handleInput: _parseInput: failed controller.runCmd(RESTORE) can only concatenate str (not "int") to str Traceback (most recent call last): File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/interface.py", line 795, in _handleInput self.nodes_internal[item['address']].runCmd(item) File "/var/polyglot/.local/lib/python3.8/site-packages/udi_interface/node.py", line 165, in runCmd fun(self, command) File "/var/polyglot/pg3/ns/00:21:b9:00:f1:fd_7/nodes/backup.py", line 123, in restore cmd = '/rest/nodes/' + address + '/cmd/DON/' + self.CustomData[address]['value'] TypeError: can only concatenate str (not "int") to str 2022-05-28 14:41:13,673 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2022-05-28 14:41:13,675 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2022-05-28 14:41:13,723 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll
bpwwer Posted May 29, 2022 Posted May 29, 2022 Seems like that used to work. I wonder if a new version of Python is now more strict about that sort of thing.
bpwwer Posted May 29, 2022 Posted May 29, 2022 Try version 2.0.4, I made some changes that I think should fix that.
hart2hart Posted May 29, 2022 Author Posted May 29, 2022 On 5/29/2022 at 12:16 AM, bpwwer said: Try version 2.0.4, I made some changes that I think should fix that.Thanks it works great. For use cases where only a few lights change state, would it be worth considering grabbing the current state at start of restore , comparing before and after state, and only sending REST commands where they are different? Kinda a temporary scene? Add a Restore Differential button?
bpwwer Posted May 29, 2022 Posted May 29, 2022 Added this to the issues list for the node server so I've captured the request.
hart2hart Posted May 29, 2022 Author Posted May 29, 2022 On 5/29/2022 at 2:48 PM, bpwwer said: Added this to the issues list for the node server so I've captured the request.Thanks. Obviously not even close to a priority, it just hit me while I was testing.
