Announcing Wake-On-Lan
Since IoP no longer has support for Wake-On-Lan built in, we need a way to schedule and/or trigger systems to wake up.  This node server allows you do do that.
It is a very simple node server.   To configure it you add custom parameters with a host name as the key and the mac address and IP address as the value.  The host name is just for display purposes.  The mac address and IP address are formatted as XX:XX:XX:XX:XX:XX/192.168.1.1 It's not picky about the separator character used for mac address (or if there even is one).
For each custom parameter a node will be created.  The node supports one command - send WOL packet to the host.
If there are any additional features or improvements, let me know.
