Leak Sensor 2852-222
I have a leak sensor linked to a siren, to tell me if there is water in the water heater area.  It also announces on Alexa that there is a leak.  Also, it sends me a text message if there is a leak.  All this works; however, I continue to get text messages, even without a leak.
The messages came every single day at 1:00 a.m., never fail, but the siren did not sound and Alexa did not announce.  Kind of annoying, but once a day was tolerable.  Now, after some adjustments to the links, I am getting the text messages promptly every 10 minutes.  Still no siren or Alexa announcement.
Any suggestions?
Craig
Solved by MrBill
right click the programs that send notifications program name and pick copy to clipboard, then paste them into a message.  We have no idea what the programming issue is without seeing the program.   If it's programs that are linked by variables or otherwise be sure to post other interrelated programs also.
Never mind! Figured it out.  I had a repeat every 10 minutes in a program.  However, that doesn't explain why the message comes once a day.
Leak Wet Alert - Water Heaters - [ID 0008][Parent 0001]
        'Siren, Chime, Relay / Water Heater Leak .2 - Wet' Status is On
        Send Notification to 'Craig Sedgwick - text' content 'Wet Sensor Alert'
that program shouldn't be sending anything at 1AM. however I would send the notification off the sensor itself and not the siren which is apparently in the scene, unless that's just a confusing folder name and the device is the leak sensor.
You might right click a program name and then pick Find/Replace.  Change the drop down to "raw text" and type "Notification" without the quotes and with a Capital N and then cycle thru your programs with the find button to see if there is anything else that could be sending the notification in error.
Thanks for your help.  I will try as soon as I can.
I think I found it, thanks to your awesome help on searching through all my programs for "Notification."  It was a stray program that I don't even know what it did.  It didn't make any sense.  I deleted it, and hopefully all will be well now!
Thanks again!
