Adding wattage used as a virtual device...
I was wondering how much work it would be to add electrical usage as a display to the Virtual Device Node Server?  Let me explain... There are many devices out there now that just like remote sensor capture the temperature also capture the power usage at that point.  It would be nice to use the Virtual Device node server to be able to display this and for the way I want to use it, I have tested it already and I can make it work...  My issue is that my power usage display now shows me that I have used 50 F :)  The numbers are correct and in principal it works but it only allow F or C ... Can you add the option to select W/h as a symbol or measurement choice?
Thanks and regards
I have found a use to track a number that is not temperature also. I would like to be able to have nothing after the number or have it be that we can add anything we like because mine would be % but I have the ability to add it in Housepanel if I need to.
