MobiLinc Pro 2.11 is Available on the App Store!
Hi all,
MobiLinc Pro 2.11 is Available on the App Store! Here are the following features found in 2.11:
- Name change to MobiLinc.
- Option to set programs as favorites
- Performance enhancements
- Under My Settings, option to enter in your own custom text that directs MobiLinc to auto-hide any scene, device, or program that starts with this custom text. This is useful to hide a device, scene, or program from all your iPhones or iPod Touches by prepending this text to the beginning of a device, scene or program name.
- Shake the iPhone or iPod to jump to the MobiLinc startup page.
- Other bug fixes.
Wes
Strange...
I just upgraded from iLinc to Mobilinc Pro 2.11 and now the app doesn't load anymore on my iPod Touch...(version 3.1.2) When I press on the program's icon, the Mobilinc stratup screen shows up, and as usual at the bottom of the screen a blue progress bar appears (it says Loading Profile: Default), then, the app closes immediately :twisted:
Whan can I do????
I was so appy with this app before, can I revert to the older version?
Hi stef2,
I'm sorry to hear MobiLinc is failing to start for you. Do you have any thermostats in your setup? I received a report yesterday that indicated for some users with thermostats upgrading from 2.10 to 2.11 caused a startup crash. The root of this problem is under investigation, but there is a workaround. Please remove MobiLinc from your device and re-install MobiLinc from iTunes. This will force the settings and database to clear out allowing MobiLinc to cleanly sync with your ISY.
Please post back the results of the re-install.
I apologize for the inconvenience.
Wes
Fabulous upgrade Wes!
The ability to add programs to the Favorites panel is especially useful.
-Jim
Hi stef2,
I found the issue with the startup crash. Here are the details:
Problem: There was an issue in the 2.11 release where if a user was upgrading from 2.10 to 2.11 AND the user had changed the thermostat setting outside of MobiLinc from the iPhone/iPod Touch Settings page in 2.10, version 2.11 would crash on startup.
Temp Fix: Once 2.11 is installed go to Settings->MobiLinc Pro and select either Fahrenheit or Celsius from the Thermostat Display options. Launch MobiLinc. OR remove MobiLinc and reinstall from iTunes.
I've released a fix (2.12) to Apple and am awaiting approval.
2.12 also fixes a bug with how MobiLinc pulls the My Settings -> “Hide Text†from the internal database.
Wes
Thanks - back up and running!!!
