January 31, 201016 yr I recently upgraded to 2.7.10. I have noticed there is a new tool called batch mode. how does that apply to my system and Should I do anything? I could not find any documentation on this. It is off right now. Should I turn it on? What will happen?
January 31, 201016 yr Batch mode, when On, allows you to create scenes and change parameters without writing the links to the devices. After you have made all your changes you can switch batch mode off and walk away while all the links are pushed out. Next to Batch Mode on the toolbar is Battery Mode. This delays writing links to battery powered devices much like the batch mode functions with wired devices. Rand
