ambient weather PG3 key and value
I did this a few years ago for PG2,   What am i missing?   Setup new key in ambient weather. have an application key and the new key i called Polisy.  What do I enter for key and what do I enter for value. I assume enter the key in the key location and in this case nothing for value.
Lost on a simple item .
2022-06-28 16:42:00,934 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2022-06-28 16:42:03,419 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.46 Starting... 2022-06-28 16:42:03,432 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.0.63 [ISY: 5.4.4, Slot: 6] 2022-06-28 16:42:03,434 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.104', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2022-06-28 16:42:03,435 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:1888 2022-06-28 16:42:03,441 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'config': {'version': '2.0.6'}} 2022-06-28 16:42:03,483 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2022-06-28 16:42:03,485 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:56:0c:24_6 - MID: 1 Result: 0 2022-06-28 16:42:03,498 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,) 2022-06-28 16:42:06,601 Thread-1 udi_interface ERROR ambient-poly:discover: Missing API key
here is what I used in PG2.
For PG3
do i need to add the  app_key   and what is its format
for the api_key                                   what is its format  APIKey ?
lets put this down to jumping in before looking.  Setup my key as APIKey and enter the value.  Nothing worked.  Finally delete and reinstalled the node and notice Key format API Key,  need the space.  Might want to fix the configuration instructions.
Configuration
The Ambient Weather node server has the following user configuration parameters:
  • APIKey : Your API Key, needed to authorize this node server to connect to the Ambient Weather server and retrieve your data.
