moving Ecobee from Pg2 to Pg3 nodes not completing installation in IoP
On moving Ecobee from Pg2 having problems getting the nodes to install correctly in IoP.  Nodes show up in PG3 for the 3 ecobees ok.
Getting error measages saying divers not found in the log file (included below )
here is what i see in IoP after hitting install all nodes in IoP.    It has a long way to go to match PG2 interface.
Tried to delete and reinstall get same results.
 Eric
Ecobee_7-13-2022_122129_PM.zip
Mine did a similar thing but I can't remember what I had to do. I did have to reinstall the PIN key into the ecobee website setup. The first one took OK and then failed right after for some reason.
With mine I deleted PG2 ecobee NS as I moved. New stat and new PG3 install. Not sure if that made any difference. Check the ecobee NS logs. IIRC I had several PIN rejected lines inside the log.
Most of the time you have to at least reload the admin console. Most of the setup is a load with boot-up thing. Admin console is not dynamic in many cases.
