ISY994 Pro unable to control Insteon Devices?
Hi,
I am a long time ISY / Insteon user.  Everything has been great for a long time.  Two days ago I noticed the system was sluggish.  I rebooted the ISY & I dont seem to be able to control anything through the ISY.
I am using version 5.3.4.
I have powered off the ISY, unplugged the PLM.  Waited a few minutes, plugged it back in & nothing is happening.    This seems to repeat itself for a long time.
PLM Status says:  48.EA.41 V9E connected.
Any suggestions - the ISY is responding normally but there is no lighting changes.
Rich
Elapsed 00:00:10.297 : Loading Variables
Elapsed 00:00:11.109 : Loading Node Definitions
Elapsed 00:00:11.797 : Loading Nodes
Elapsed 00:00:14.000 : Creating Widgets
Elapsed 00:00:20.203 : Creating Widgets Complete
Fri 07/15/2022 11:16:50 AM : Starting Subscription
Fri 07/15/2022 11:16:51 AM : Completing initialization
Fri 07/15/2022 11:16:51 AM : Refreshing Status
Fri 07/15/2022 11:16:51 AM : Refreshing Views
Fri 07/15/2022 11:18:46 AM : [All         ] Writing 472 bytes to devices
Fri 07/15/2022 11:19:35 AM : [INST-SRX    ] 02 50 51.F2.C8 00.00.01 CB 13 00    LTOFFRR(00)
Fri 07/15/2022 11:19:35 AM : [Std-Group   ] 51.F2.C8-->Group=1, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:36 AM : [INST-SRX    ] 02 50 51.F2.C8 48.EA.41 41 13 01    LTOFFRR(01)
Fri 07/15/2022 11:19:36 AM : [Std-Cleanup ] 51.F2.C8-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Fri 07/15/2022 11:19:36 AM : [INST-DUP    ] Previous message ignored.
Fri 07/15/2022 11:19:36 AM : [INST-SRX    ] 02 50 51.F2.C8 13.01.01 CB 06 00           (00)
Fri 07/15/2022 11:19:36 AM : [Std-Group   ] 51.F2.C8-->13.01.01, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:36 AM : [INST-INFO   ] Previous message ignored.
Fri 07/15/2022 11:19:36 AM : [INST-SRX    ] 02 50 51.F2.C8 00.00.01 CB 11 00    LTONRR (00)
Fri 07/15/2022 11:19:36 AM : [Std-Group   ] 51.F2.C8-->Group=1, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:37 AM : [INST-SRX    ] 02 50 51.F2.C8 11.01.01 CB 06 00           (00)
Fri 07/15/2022 11:19:37 AM : [Std-Group   ] 51.F2.C8-->11.01.01, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:37 AM : [INST-INFO   ] Previous message ignored.
Fri 07/15/2022 11:19:37 AM : [INST-SRX    ] 02 50 51.F2.C8 00.00.01 CB 13 00    LTOFFRR(00)
Fri 07/15/2022 11:19:37 AM : [Std-Group   ] 51.F2.C8-->Group=1, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:38 AM : [INST-SRX    ] 02 50 51.F2.C8 48.EA.41 41 13 01    LTOFFRR(01)
Fri 07/15/2022 11:19:38 AM : [Std-Cleanup ] 51.F2.C8-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Fri 07/15/2022 11:19:38 AM : [INST-DUP    ] Previous message ignored.
Fri 07/15/2022 11:19:38 AM : [INST-SRX    ] 02 50 51.F2.C8 48.EA.41 46 13 01    LTOFFRR(01)
Fri 07/15/2022 11:19:38 AM : [Std-Cleanup ] 51.F2.C8-->ISY/PLM Group=1, Max Hops=2, Hops Left=1
Fri 07/15/2022 11:19:38 AM : [INST-SRX    ] 02 50 51.F2.C8 13.01.01 C7 06 00           (00)
Fri 07/15/2022 11:19:38 AM : [Std-Group   ] 51.F2.C8-->13.01.01, Max Hops=3, Hops Left=1
Fri 07/15/2022 11:19:38 AM : [INST-INFO   ] Previous message ignored.
Fri 07/15/2022 11:19:38 AM : [INST-SRX    ] 02 50 51.F2.C8 00.00.01 CB 11 00    LTONRR (00)
Fri 07/15/2022 11:19:38 AM : [Std-Group   ] 51.F2.C8-->Group=1, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:39 AM : [INST-SRX    ] 02 50 51.F2.C8 48.EA.41 41 11 01    LTONRR (01)
Fri 07/15/2022 11:19:39 AM : [Std-Cleanup ] 51.F2.C8-->ISY/PLM Group=1, Max Hops=1, Hops Left=0
Fri 07/15/2022 11:19:39 AM : [INST-DUP    ] Previous message ignored.
Fri 07/15/2022 11:19:39 AM : [INST-SRX    ] 02 50 51.F2.C8 11.01.01 CB 06 00           (00)
Fri 07/15/2022 11:19:39 AM : [Std-Group   ] 51.F2.C8-->11.01.01, Max Hops=3, Hops Left=2
Fri 07/15/2022 11:19:39 AM : [INST-INFO   ] Previous message ignored.
Fri 07/15/2022 11:19:39 AM : [INST-SRX    ] 02 50 51.F2.C8 00.00.01 CB 13 00    LTOFFRR(00)
Hi - Yes it says system busy in orange on the bottom left.  Been this way for hours.
Hi - I added a lamplinc & I guess that caused the issue.  When I removed it from the wall & deleted it, things are back to normal?
