If zone running no longer triggers program
Hi @glarsen
I have been without issues for many months now...Thanks
Starting last Sunday my programs stopped triggering when a zone was turned on. I had made no changes to anything. This morning I updated my PG3 and all programs via the ISY on Polisy admin interface, to see if that would fix the problem. No change. I am able to turn zones on and off fine. Just the status is wrong and if I do a query while a circuit is running it does not show as running...always idle. Has anyone else seen this. I have attached various screen shots and logs below. The log file was captured while a program was running this am. Note RZ check program last run time of SaturdayThanks
RainMachine_7-25-2022_111030_AM.zip
Edited by stevehoyt
This is the PG2 forum, there's a separate forum for the PG3 version.  I don't see any issues in either log and am unable to replicate the issue here yet.
Edited by glarsen
sorry for posting to the wrong forum. I am still trying to isolate the issue. @glarsen
Same problem today. Status not changing anymore to running. Could you take a look at attached  ( isy and Pg3) log files and let me know if you see anything wrong. Watering started on circuit 3 at 11:00 and circuit 8 around 11:02. After no change in status, I did a manual query, for each about 30 seconds after starting. I have no idea what each field means but am guessing ST set to 0 might be status. Is that what would be normal.
I had rebooted the IoP this AM and restarted the Node server yesterday. Maybe tomorrow I will reboot the rain machine. Any trouble shooting ideas would be appreciated. I can't imagine how it could possibly affect the Node server, but the only thing that has changed is that I signed up for the yearly subscription plan from rain machine that permits remote access.
Steve
RainMachine_7-26-2022_110400_AM.zip ISY-Events-Log.v5.4.4__Tue 2022.07.26 11.04.17 AM.txt
Hi @stevehoyt,
Sorry Steve, I'm away on vacation until after the middle of August with limited access to any development systems.  I'll try look through your attachments but it's a little hard on a phone screen.  I'll let you know if anything obvious shows.
G
Good News
It looks like something went wrong in PG3. I restarted it and all appears to be back working.
Enjoy the rest of your vacation. I won't bother you if I see any issues until you get back.
Thanks for your help.
