PG3 Links - iTach IR
Couple of items:
  1. In the PG3 Store when I click on the iTach IR hyperlink within the PG3 store to get more info on the Node server it takes me to the 'open sprinkler' repository
  2. After I install the Node server and go to configuration a message displays showing "Please set or check open sprinkler password and IP Address"
Edited by jwagner010
Solved by Javi
Hi @jwagner010,
Thanks for the report.  I'm not sure how this happened, but the production store was pointing to the open sprinkler repo.   If this is was a new install please uninstall then reinstall so the correct parameters are populated.  Updated to version 2022.08.01
