Ran update packages which changed Python to 3.9.13 from 3.8.13
@bpwwer I was trying to update my ELK node server on PG3 and I ran the update packages which changed Python to 3.9.13 from 3.8.13 and now none of my PG2 node servers will start and only some of the PG3 ones are starting.  Any ideas?
Yes, UDI's upgrade script failed.
As part of that upgrade it is supposed to re-install all the python packages so that all the 3.9 versions are installed, but that doesn't seem to have happened.
I don't believe there's any user accessible way to fix this, right @Michel Kohanim.  Other than removing and re-installing each node server.
Thank you, that is what Jimbo suggested too and it seems to be working.  Just remember to use the same slots or things won't match up in the IoP.  With PG3 all you need to do is install the same node server in a different slot and delete it and restart the original.  A little more time consuming in PG2.
Edit: A lot more work, you need to save all programs with devices from PG2 in the them.  Ugh!
Edited by btreinders
