February 10, 201016 yr I am trying to program lights to come on for two minutes when a program is activated, then turn off. The "then" section looks like this: Set lights on wait 2 minutes Set lights off What happens is that the lights flash, then turn off. Obviously, my command is wrong. What is the correct command to activate an instruction for a finite amount of time? Thanks in advance for any help.
February 10, 201016 yr There's nothing wrong with what you posted, must be a problem with another part of the program. Can you post the program in its entirety?
February 10, 201016 yr Author Thanks for getting back. The "If, Then" commands go like this: If Status "Keypad A-F2 Vacation Flag" is on Then Set Kitchen Light on Wait 2 minutes Set Kitchen light off Else nothing Having the kitchen lights turn on is a confirmation that all programs associated with F2 are activated. When I activate (turn on) keypad A, the kitchen lights flash and have stayed on for as long as 2 seconds, then go off. Should I insert an "kitchen lights on/off" in the Else section?
February 10, 201016 yr I wonder if one of your vacation programs (associated with F2) is turning off the kitchen lights?
February 10, 201016 yr I am wondering, like TS99, if your "keypad A-F2" is in a scene with your kitchen lights. I am also wondering if you would be better served if you use "control" for your condition, rather than "status". A remote (in my mind) possibility is communication problems. Though I don't think I have seen this, I wonder if some devices flash their load if experiencing comm problems. I know that the keypad lights do.
February 11, 201016 yr Author fitzpatria8 That was it. I checked the other programs within the F2Vacation Flag and found that the kitchen light program had a "kitchen lights off" in the "Else" section. When I removed the "Else" off command and activated the F2 program, the lights came on and stayed on for the specified time. Thanks for your help. I would not have thought to look there. oberkc-thanks for chipping in. I is very nice to have capable help to solve, for me, a difficult problem.
