a way to use multiple accounts/APIs?
Would it be possible to provide support for multiple Airthings APIs, each with its own separate set of devices? If not within the same NS, can multiple NS instances be deployed on same Polisy or would one have to deploy multiple Polisy's to achieve this?
Hi @JimboAutomates, just wondering if this is technically possible as a first step regardless of whether or not you would consider doing it for this NS. This is as much a PG/NS 101 question for any NS that calls an API as it is for doing it for this particular NS.
If it is technically possible, with respect to the issue of choosing to add support for multiple API's, I'd be fine to pay for each API supported should that be an important consideration.
Any info would be appreciated.
@johnnytYou can run to copies of the Airthings node server in different slots.  Your current license allows you to run multiple copies.  Weather or not the node server will allow each instance to control a subset of the devices on your account depends on the node server.  You may need to create multiple accounts and have each instance use a different account.
