February 12, 201016 yr Referencining the following program: If Status 'MBR Bath Fan' < 95% And Status 'MBR Bath Overhead' < 5% Then Set 'MBR Bath Fan' 85% Wait 8 minutes Set 'MBR Bath Fan' Off Else - No Actions - (To add one, press 'Action') the MBR Bath Fan runs continuously. When it's shut off, it restarts in about 15-minutes. My problem is how to properly trigger 'Then' conditions I'd like to trigger them when the fan is on at 100% and when OFF is pressed on the MBR Bath Overhead switch. the fan is an ICON switch the MBR Bath Overhead is an INSTEON Dimmer I've tried several different combinations of status and control conditions and can't get this to be repeatable. Any Suggestions. If the 'Then' portion of a program is executing and the 'If' conditions are toggled from false back to true, will the program reset and restart the 'Then' portion again? if the 'Then' portion of a program causes the 'If' condition to toggle to false, while 'Then' is still running -- what happens?
February 12, 201016 yr Author back to the old test board to try and further examine this issue. Found out what appears to be a problem: If Status 'TestBoard 2' is not Off And Control 'TestBoard 4' is switched Off Then Set 'TestBoard 2' 50% Wait 5 seconds Set 'TestBoard 2' Off Else - No Actions - (To add one, press 'Action') Test: turn 2 on (full) turn 4 on (full) turn 4 off program runs 'then but only executes the first line then quits. Leaves 2 at 50% turn 4 back on turn 4 off program runs 'then' runs all 3-lines. second and third line don't seem to run unless 2 is already at 50%! both switches are 2476D's V4.35 (isy v.2.7.9)
February 13, 201016 yr When you change the Status of Test2 the Conditions are reevaluated and since the switch is not turned off again the program changes to False. Put your Actions in a second program and call it from the current program. Rand
February 14, 201016 yr Author Rand - Thanks! I've had several programs that wouldn't perform the way I thought they should - They can all be traced back to this little ANOMALIE...whatever you want to call it. It all comes down to knowing what causes IF conditions of a program to trigger and be evaluated. I've never found anything written that talks about this. Don't mean to dump on you guys but, like so many other things about the ISY, it's not described in a manual. It's like you just assume folks would know it. I can tell you, from the perspective of a programmer that's trying to learn your "language", THIS IS VERY FRUSTRATING!!! It appears that, whenever the conditions of ANY DEVICE in the IF statement changes: (1) ALL the 'IF' conditions are immediately re-evaluated. (2) if the 'THEN' processes are currently executing - they all stop. (3) the 'THEN' processes coditionally execute, based on the new evaluation of the IF conditions. I've NEVER seen a programming envrionment behave this way! Once a series of 'THEN' processes have begun, NOTHING should be allowed to interrupt it. IF re-evaluations processing should be suspended while this is going on. I suppose, once you've become accustomed to this, it might seem logical but, right now to me, it seems really wierd! Dave
February 14, 201016 yr Hello Dave, Programs are evaluated whenever a schedule is met or a change is made to a referenced device. The only time a program is halted when conditions change is during a Wait or a Repeat loop. It is documented in the Wiki: ISY-99i/ISY-26_INSTEON:Scope,_Precedence_and_Execution_Order#Statement_Execution_Order. For more information on programming the How-To Guide has a list of articles and examples: ISY-99i/ISY-26_INSTEON:How-To_Guide#Programs Rand
