How I am Using Programs as Flags
Just Another Joe, and anyone else,
This is how I use my Flags Programs.
Now that I understand Program Status I can use them as Flags for other things.
Thanks to Alf for the Program Status Explaination. and Clarification.
Since the Program Status is dependent on the conditions within the program code, I can now use the "True"/ "False" status as a Flag. Here are some examples that I use:
This is my Daytime FLag Pgm:
It is used to indicate that it is daytime.
       From    Sunrise
       To      Sunset  (same day)
This is my Evening Flag Pgm:
It is used to indicate that it it after Sunset but befor 11:25 PM.
       From    Sunset
       To      11:25:00PM (same day)
This is my GoodNite Flag Pgm:
It idicates that my systems is flagged for things that could or should happen between about 10:00 PM and Sunrise.
       From    10:00:00PM
       To      Sunrise (next day)
The Great thing about these Flag Programs is that I don't have to reset the Flags. They are dynamicaly reset by the conditions with which they were set.
I can now use their "True / Flalse" valuse in my programs.
This is my 10 minute all lights on Program:
This program only runs during the time that the GoodNite flag is set.
- between 10:00 PM and Sunrise.
            Program 'GoodNite Flag Pgm' is True
        And Control 'Front Walkway Light' is switched Fast On
       Wait  2 seconds
       Set  Scene 'All On Scene' On
       Wait  10 minutes
       Set  Scene 'Good Nite Scene' On
It also Great for Motion Detection during the GoodNite Hours.
I keep all of my Flag Programs in a Flags Folder. That way they are easier to find.
I found one mistake in my earlier post.
In the GoodNite Flag Pgm, the code for Sunrise should be "Same Day".
       From    10:00:00PM
       To      Sunrise (same day)
I tested this today and it is Same Day. I would have thought Next Day also but it proved to be wrong.
C Martin,
Looks like you discovered a bug ... its in a complex area of the code that affects all schedules using sunrise/sunset, so I'm not sure if we will fix it with the official release coming up so soon.
In cases where the 'From' time is greater than the 'To' time, 'Same Day' is behaving the same as 'Next day'.
Just for clarification, are you saying you tried 'Next Day' and it didn't work, or that you are using 'Same Day' and never tried using 'Next Day'.
I would suggest using 'Next day' because I believe this bug will be fixed at some point in the future.
No, I used the Next Day value and this morning it was wrong, so I changed the Value to Same Day. I will check again tomorrow by chnging values again.
C Martin,
Thank you for the examples. I spent a few minutes Saturday trying to make an "Away" button on my KPL but I could not get it to function properly.
Now that I have read about 2.4.13 not deleting all the old links I realize why the ISY is not seeing the button state and the lamp keeps changing with the button :lol:
Thanks again,
Rand
Clarence, thank you! Flags ala your programs will alleviate a lot of problem areas, pending the introduction of genuine variables. Well done! 8)
I will try to post some more examples later this week.
I have a rain Switch that enables my folder that has my irrigration controller programs. It can diable the folder for a set amount of time and then send reminders.
Doing a Flags program for scenes will be a little harder because scenes allow for more unit values for lighting levels than the Staus event in the IF progam area can evaluate. It requires the use of greater than (>) or less than (<) to capture an Insteon's set level.
More later!
In all the examples above, the conditions which control the Flag program are all time events. Is there any action statement one can place in a separate program [without actually turning some Insteon device on/off] which would cause a Flag program to change state?
Whenever a program runs, it is either set True ('Then' path) or False ('Else' path), therefore you can use any conditions in your 'If' to set a program to True or False.
You can use Actions to explicitly set flags as well; create an empty program named 'Flag 1', and in other programs use the 'Program' 'Run' 'Flag 1' action to set 'Flag 1' true, and use 'Program' 'Run Else' 'Flag 1' to set Program 'Flag 1' false.
Chris,
I thought that I had seen the Flag program status change during calls by other programs. In matter of fact I was doing calls to my Flags Progams but changed from that.
After your post I re-tested doing the progam calls and I find that to be a more reliable way of asurring that the flag programs are either set or re-set.
This way I can depend on my Sunset Program to set my evening Flag Program rather than just looking at the IF statements.
Two questions though -
Do the program statuses otherwise change only when there is program activity on the ISY?
If not, any idea how long it my take to see a status change? - just curious...
Clarence
Clarence,
Actually, I think the way you had it is good, and how it was intended to be used. Basically create programs such as 'Evening', 'Daytime', 'Office Hours', 'Holidays' etc. containing 'If' conditions only, and then have other programs reference those programs directly.
As for when the True/False state is changed ...
The only time the True/False status is changed for a program is when that program is run.
The first step in running a program is to set the True/False status, it then begins to perform the actions in either the 'Then' or 'Else'.
Nothing else changes the True/False status of a program.
You can also nest program refererences as deeply as you like. For example, you can have a bunch of holiday programs 'Christmas', 'Thanksgiving', etc. and then have program that references them called 'Days Off'.
Program: Days Off
       Program 'Christmas' is True
    Or Program 'Thanksgiving' is True
    Or Program 'Vacation' is True
Program Vacation
       From     5:30:00PM on 2007/12/21
       To       9:00:00AM on 2008/01/07
Program Christmas
       From    12:00:00AM on 2007/12/25
       For      24 hours
Program Thanksgiving
       From    12:00:00AM on 2007/11/22
       For      24 hours
Chris,
That's great info. I wil be refining my programs.
Clarence
Super! Thanks, Chris, that's exactly what I was looking for.
  • 3 weeks later...
I'd like to have a flag program that resets itself after X time.
I tried making a test program with just a "Wait 15 seconds" in the "Then" but after I "Run" the program, it doesn't change to "False" after the 15 seconds.
I just added the Run Else line and it works as expected:
Program "test wait"
       Wait  15 seconds
       Run program 'test wait' (Else Path)
Any problems with having a program stop itself like this?
One other possibility is that after 15 seconds, the program turns False, but another program immediately runs it again using the 'Then' path, making it appear as though it never stops.
Easiest way to test this is to make a copy of this program, and run this copy directly from the program summary screen, it should show 'Running Then'/True for 15 seconds, then 'Idle'/False.
I just retested and indeed if the program has ONLY the wait action in the "Then" and is run manually, the interface blinks "Running Then" in red, then goes back to "idle" and the status changes to and stays "True" indefinitely.
It will only revert to False if I explicitly set it to "run else" after the "wait".
(and yes, i was using an old gui before ... that's all better now, thanks!)
cheers!
~shawn
