PG3 login went back to default after update (3.1.6)
Mysteriously my PG3 login went back to admin/admin, and I don't remember how to change username and password. Help anyone ?
Nothing should be able to reset the login credentials except you manually doing that (either through the menus or by running the reset_password command on the command line).   The only other way the credentials could be reset would be if the database was removed and re-created.  In that case, it would be a lot more than just credentials that would be reset.
From the menus, use the Settings -> Profile option to set the credentials
I can assure you that I did neither, but anyway I did the reset through Settings - Profile,
Edited by asbril
