GaryK4 Posted September 21, 2022 Share Posted September 21, 2022 I have (2) garage doors using the IOLinc (2450) v.41. The doors open and close properly. However the sensor is not updating. If I query the sensor in the admin console, it updates. However these updates do not get passed to the Home Assistant. I rebooted the ISY, Home Assistant computer. Unplugged the IOLinc. Still ISY is not reporting the correct status. All other devices appear to be working properly. I don't se anything in the system logs. I am at a loss what to do next! Link to comment Share on other sites More sharing options...
GaryK4 Posted September 22, 2022 Author Share Posted September 22, 2022 Does anyone have a clue how to fix this? Link to comment Share on other sites More sharing options...
larryllix Posted September 22, 2022 Share Posted September 22, 2022 Does anyone have a clue how to fix this?In the admin console select the main device entry in the device tree, right click and select Restore from the menu.Devices use multiple links for different functions and ioLinks are notorious for losing them due to design and noisy environment.Sent from my SM-G781W using Tapatalk 2 Link to comment Share on other sites More sharing options...
GaryK4 Posted September 22, 2022 Author Share Posted September 22, 2022 18 minutes ago, larryllix said: In the admin console select the main device entry in the device tree, right click and select Restore from the menu. Devices use multiple links for different functions and ioLinks are notorious for losing them due to design and noisy environment. Sent from my SM-G781W using Tapatalk You are my hero! That fixed the problem. Home Assistant is also working. Thanks so much. 1 Link to comment Share on other sites More sharing options...
Brian H Posted September 22, 2022 Share Posted September 22, 2022 Being power line only doesn't help. It also has the switching supply chip in it and different capacitor choices depending on the revision. 1 Link to comment Share on other sites More sharing options...
