Notification Sound iOS mute via Network Resources and Service Pushover
I have tried to send a sound via both the network resources and the service pushover node.  No sound from either although all messages come through perfectly.
Tested from pushover home page and the sounds work when message is initiated from there.
Any thoughts?
So restarted AC and tried service pushover again and it worked.  Edited a network recourse saved and tested both methods and did not work.  Restarted AC tried service pushover with screenshot setting and it did work again.... very strange.
So currently not touching anything and it appears to be working....
I don’t think so as I can go to the pushover web and do a test push w sound and it works while from isy it does not.  Will keep playing and see if I can consistently have it fail so we can troubleshoot.
As mentioned working now so maybe I should leave well enough alone!
