Motion Detector not showing motion changes (On/0ff) on ISY
After replacing battery in Motion Detector (2844-222), it will not show status changes when motion detected.  I have done factory reset and removed/re-added it to the ISY.  I can query it, change option settings, and query the low battery status, but the ISY will not show changes from motion detection (on/off).
Any suggestions would be appreciated. Thanks.
Solved by larryllix
Have you allowed enough time for the Linking mode to reset or reset it manually?
Put the MS in linking mode and examine the options. Some can lock the MS out after motion for quite a long time.
Have you tried a "Restore" on the device after it was set up?
Can you show a screen shot here of your option page  after putting it in linking mode?
Thanks much for your reply.  After a few minutes it started working correctly.  I think I did not give the MS enough time to stabilize with new battery, or I did not reset the linking correctly with 2 presses of "set" button.  In any case it is now working correctly.
