Posted February 25, 201015 yr I just had a Lamplinc go bad on me so I replaced it (2456D3) I drop it into one of my scenes and it works fine, except it is on 100% or fast off -- the settings I make in the scene don't seem to work from the controller (KPL) If I turn the scene on and off from the computer it works fine and will ramp at the speed I set it to and level? Am I doing something wrong? I have not had to do much with my network for a couple of years and I may have forgotten something? FYI I am using the ISY26 Thanks Glenn
February 25, 201015 yr Hello Glenn, Within the scene select the KPL as the controller. Then adjust the level and rate or Copy Scene Attributes. Rand
February 25, 201015 yr Author That did it -- Thanks Rand. When something works this well you forget how you set it up -- I guess that's the sign of a good stable system!!
