Production or Non-Production?
I purchased and installed the Node server when it was only in the non-prodcution store and it is labeled as Beta.  Works great for my very limited use of LED strips.
I now see it in the production store with same version number.  Simply for future support purposes, should I install again from the production store?
You can, but at this point, there isn't any difference between the two.  Future updates (if any) will only be available on the production version.
If you attempt to install the production version, it should give you the option to re-install in the same that has the beta version installed.  This will update your installation to point at the production store entry.  I don't believe it will effect anything else.
That confirmed my thought process. Reinstalled from production store and devices all remained the same. The polling intervals did revert to defaults. At least shortpoll did as I had lowered it a bit below default.
