Enbrighten Z-Wave Smart Toggle Light Switch LED
Has anyone gotten the Enbrighten Z-Wave Smart Toggle Light Switch LED to illuminate?
(Optional toggle guide light – The white, toggle-style switch illuminates to show switch location and status. A blue LED backlight provides a soft glow and can be reversed, turned off or always on based on your indicator preferences)
LED status can be inverted manually changed to invert, always OFF and always ON
I have read the instructions over and over - no light
Solved by Jim P
These are from my GE ZWave light switch (46202)  .. I believe they are made by JASCO .
0 - On when light switch is OFF and Off when switch is on
1 - Off When sw is on and on when switch is off
2 - Off all the time
When shipped from the factory, the LED is set to turn ON when the connected light is turned OFF. This is the default setting and can be changed if your primary controller supports the node configuration function. To make the LED turn ON when the light is turned ON, change parameter 3’s value to “1”. To turn the LED OFF at all times, change parameter 3’s value to 2.
    Parameter No: 3
    Length: 1 Byte
    Valid Values = 0, 1 or 2 (default 0)
Invert Switch
If the switch is accidentally installed upside down with “On” at the bottom and “Off” at the top, the default On/Off rocker settings can be reversed by changing parameter 4’s value to “1”.
    Parameter No: 4
    Length: 1 Byte
    Valid Values = 0 or 1 (default 0)
Alternatively, the LED default setting can also be changed at the switch.
To disable the LED indicator:
    Press the "ON" switch 3 times successively
    Press the "OFF" switch 1 time
Thank you!
Tried doing at the switch, I will try with polisy
I wasn't tapping quick enough at the switch.
Thank you!!
