Admin console never appears
I have been using the ISY994 for several years with lots of successful automation. In fact it is still working and I am able to connect using MobileLinc and see that my devices and programs are working as expected.
However I am now unable to access the console to see and modify my programs. It simply never appears although before today it has always worked. I can start the dashboard from the ISY finder, but not the admin console. The JAVA starts to run and then just stops. No console is displayed.
I have (after reading all I can find in the FAQs and documentation and this site):
1. Rebooted the PC I am using
2. Rebooted the ISY994 along with all of the routers and switches
3. Updated JAVA
4. Cleared the JAVA caches (trace and log files, cached applications and applets, installed applications and applets)
5. Checked the JAVA security (high) and added https://isy.universal-devices.com to the exception site list
6.Verified that no VPN is running
I have enabled the JAVA console and run with level 5 logging:
Java Web Start 11.351.2.10
Using JRE version 1.8.0_351-b10 Java HotSpot(TM) Client VM
JRE expiration date: 2/18/23 12:00 AM
console.user.home = C:\Users\Tom
😄 clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
0-5: set trace level to <n>
Trace level set to 5: all ... completed.network: Cache entry not found [url: https://192.168.1.251/admin.jnlp, version: null]
network: Connecting https://192.168.1.251/admin.jnlp with proxy=DIRECT
network: Connecting socket://192.168.1.251:443 with proxy=DIRECT
https://192.168.1.251/web/insteon.jar
https://192.168.1.251/WEB/CE.JAR
https://192.168.1.251/web/chart.jar
https://192.168.1.251/WEB/RXTX.jar
network: Cache entry not found [url: https://192.168.1.251/web/insteon.jar, version: null]
network: Connecting https://192.168.1.251/web/insteon.jar with proxy=DIRECT
network: CleanupThread used 1 us
network: Downloading resource: https://192.168.1.251/web/insteon.jar
    Content-Length: 4,272,840
    Content-Encoding: null
network: Wrote URL https://192.168.1.251/web/insteon.jar to File C:\Users\Tom\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\34\2fa95462-7e4bc1a6-temp
security: blacklist: check contains PxGoXf5oZMHDrF5lVggwNnFQBfwTd0TR5vSW1igb4FQ=, state now IN_MEMORY
security: blacklist: not  found in cache
security: Trusted libraries list file not found
cache: Create from verifier: JarSigningData{hasOnlySignedEntries=true, hasSingleCodeSource=true, hasMissingSignedEntries=false}
cache: Adding MemoryCache entry: https://192.168.1.251/web/insteon.jar
cache: MemoryCache: removed entry https://isy.universal-devices.com/launcher/isy.jnlp
cache: MemoryCache: removed entry https://isy.universal-devices.com/launcher/udlogo.png
network: Cache entry not found [url: https://192.168.1.251/WEB/CE.JAR, version: null]
network: Connecting https://192.168.1.251/WEB/CE.JAR with proxy=DIRECT
network: Downloading resource: https://192.168.1.251/WEB/CE.JAR
    Content-Length: 113,554
network: Wrote URL https://192.168.1.251/WEB/CE.JAR to File C:\Users\Tom\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\19\40933293-33a994f4-temp
security: blacklist: check contains l2+GfWmyo73w+lYKaqWCx+5pVtJ6TySusbXhUrneU7U=, state now IN_MEMORY
network: CleanupThread used 0 us
cache: Adding MemoryCache entry: https://192.168.1.251/WEB/CE.JAR
Solved by MrBill
Windows or Mac?
It appears you're using admin.jnlp to open the admin console, that might be the best answer for Mac, but if using Windows, please clear the java cache again and switch to the ISY Launcher.    (many Mac users also have no problem using the ISY Launcher, however some must use admin.jnlp)
I really tried to include everything but PC no longer has the Windows connotation anymore:
Edition    Windows 10 Pro
Version    21H2
Installed on    ‎1/‎28/‎2021
OS build    19044.2130
Experience    Windows Feature Experience Pack 120.2212.4180.0
Like I said - I have read all the Troubleshooting section so I am indeed running ISY Launcher already. The screen shot is what it looks like on my Windows PC.
Choosing either LAN or CLOUD hangs in the same spot in JAVA with no Admin console ever appearing. This is new behavior in the last day.
I will add that once you request the Admin Console from the pop-up and it hangs, I can no longer exit by hitting the X in the corner, I must use Task Manager to kill it.
Additional information from the Dashboard (which does appear upon request):
