portal access token expired
Solved by bpwwer
Is it really this message: "Portal Access Token Expired. Refreshing..." ?  If so, that's not an error, it's a warning.
The token is only good for about 1 hour and then it needs to be refreshed (or you need to re-login to the Portal). PG3 attempts to refresh it automatically when it detects that it expired.  So unless it fails to refresh, it's behaving as intended.
@bpwwerOkay, thank you.  I was having another problem with my PG3 and I thought that this "token expired" problem was it.  Thank you.
