Setting Global User Preferences for Span not working
Android 10
UD Mobile .175
Setting Global User Preferences / Span to 1 results in favorites being displayed as span value of 3 or greater. I can't tell what the value actually is since it expands across the screen on my phone. Setting the span value back to default allows the span values as set for each device to work again.
As you can see below the span value is 1, but since I have set the Global value to 1 the favorites appear spanned across the screen.
6 minutes ago, kzboray said:
Android 10
UD Mobile .175
If the global default span is set to 1 there will be one item per row unless a favorite has a span greater than the default value in the same favorite folder.  https://wiki.universal-devices.com/index.php?title=UD_Mobile#Span
Some of the default values have a span greater than one for widgets.  So if default is 1 widget default is 3 the span for that folder is now 3.
I think the behavior you are looking for is default span 1 and widget span 1 (not default).
