After PG3 Upgrade, may be having a problem?
I updated to PG3, changed my short and long poll as advised (1800, 43200) and Weatherbit otherwise seems to be working, but I have noticed that the temperature and rain rate didn't seem to be changing and I see the following in the log file (below) - is this a problem?
2022-12-07 01:28:51,138 Thread-457 udi_interface      ERROR    udi_interface:write: Exception in thread
2022-12-07 01:28:51,142 Thread-457 udi_interface      ERROR    udi_interface:write: Thread-457
2022-12-07 01:28:51,143 Thread-457 udi_interface      ERROR    udi_interface:write: :
2022-12-07 01:28:51,143 Thread-457 udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-12-07 01:28:51,144 Thread-457 udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2022-12-07 01:28:51,149 Thread-457 udi_interface      ERROR    udi_interface:write: self.run()
2022-12-07 01:28:51,150 Thread-457 udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2022-12-07 01:28:51,154 Thread-457 udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-12-07 01:28:51,155 Thread-457 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db953c604_6/nodes/Controller.py", line 128, in poll
2022-12-07 01:28:51,157 Thread-457 udi_interface      ERROR    udi_interface:write: self.q.query_forecast(False)
2022-12-07 01:28:51,157 Thread-457 udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db953c604_6/nodes/query.py", line 154, in query_forecast
2022-12-07 01:28:51,159 Thread-457 udi_interface      ERROR    udi_interface:write: node.update_forecast(f_obs, float(self.elevation), float(self.plant_type), float(jdata['lat']))
2022-12-07 01:28:51,160 Thread-457 udi_interface      ERROR    udi_interface:write: AttributeError
2022-12-07 01:28:51,161 Thread-457 udi_interface      ERROR    udi_interface:write: :
2022-12-07 01:28:51,162 Thread-457 udi_interface      ERROR    udi_interface:write: 'NoneType' object has no attribute 'update_forecast'
2022-12-07 03:01:01,588 Command    udi_interface      ERROR    udi_interface:write: Exception in thread
2022-12-07 03:01:01,590 Command    udi_interface      ERROR    udi_interface:write: Command
2022-12-07 03:01:01,590 Command    udi_interface      ERROR    udi_interface:write: :
2022-12-07 03:01:01,591 Command    udi_interface      ERROR    udi_interface:write: Traceback (most recent call last):
2022-12-07 03:01:01,592 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 980, in _bootstrap_inner
2022-12-07 03:01:01,596 Command    udi_interface      ERROR    udi_interface:write: self.run()
2022-12-07 03:01:01,597 Command    udi_interface      ERROR    udi_interface:write: File "/usr/local/lib/python3.9/threading.py", line 917, in run
2022-12-07 03:01:01,601 Command    udi_interface      ERROR    udi_interface:write: self._target(*self._args, **self._kwargs)
2022-12-07 03:01:01,602 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 680, in _parseInput
2022-12-07 03:01:01,606 Command    udi_interface      ERROR    udi_interface:write: NLOGGER.setLevel('DEBUG')
2022-12-07 03:01:01,607 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 811, in _handleInput
2022-12-07 03:01:01,611 Command    udi_interface      ERROR    udi_interface:write: #LOGGER.debug('notices: {}'.format(item))
2022-12-07 03:01:01,612 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db953c604_6/nodes/Controller.py", line 136, in query
2022-12-07 03:01:01,613 Command    udi_interface      ERROR    udi_interface:write: self.q.query_forecast(True)
2022-12-07 03:01:01,614 Command    udi_interface      ERROR    udi_interface:write: File "/var/polyglot/pg3/ns/000db953c604_6/nodes/query.py", line 154, in query_forecast
2022-12-07 03:01:01,616 Command    udi_interface      ERROR    udi_interface:write: node.update_forecast(f_obs, float(self.elevation), float(self.plant_type), float(jdata['lat']))
2022-12-07 03:01:01,617 Command    udi_interface      ERROR    udi_interface:write: AttributeError
2022-12-07 03:01:01,618 Command    udi_interface      ERROR    udi_interface:write: :
2022-12-07 03:01:01,619 Command    udi_interface      ERROR    udi_interface:write: 'NoneType' object has no attribute 'update_forecast'
2022-12-07 08:31:18,399 MainThread udi_interface      INFO     polylogger:set_basic_config: set_basic_config: enable=True level=30
2022-12-07 08:31:21,837 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.51 Starting...
2022-12-07 08:31:21,980 MainThread udi_interface.interface INFO     interface:__init__: Initialization received from Polyglot V3 3.1.15  [ISY: 5.4.5, Slot: 6]
2022-12-07 08:31:21,983 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '192.168.2.60', 'netmask': '255.255.255.0', 'broadcast': '192.168.2.255'}
2022-12-07 08:31:21,986 Interface  udi_interface.interface INFO     interface:_startMqtt: Connecting to MQTT... localhost:1888
2022-12-07 08:31:22,007 MainThread udi_interface.interface WARNING  interface:start: No node server version specified. Using deprecated server.json version
2022-12-07 08:31:22,010 MainThread udi_interface.interface WARNING  interface:db_getNodeDrivers: controller not found in database.
2022-12-07 08:31:22,011 MainThread udi_interface.interface WARNING  interface:send: MQTT Send waiting on connection :: {'config': {'version': '2.0.6'}}
2022-12-07 08:31:22,831 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2022-12-07 08:31:22,833 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:0d:b9:53:c6:04_6 -  MID: 1 Result: 0
2022-12-07 08:31:22,887 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 1 - QoS: (0,)
2022-12-07 08:31:25,021 MainThread udi_interface.interface INFO     interface:addNode: Adding node WeatherBit Weather(controller) [None]
The error in the log doesn't appear to have anything to do with rain or temperature.  It looks like it is trying to update the forecast information for a forecast node that doesn't exist.
Either a forecast node didn't get created or the query is returning forecast data for more days that it should.
