Elk Output stays on past default on setting?
@Jimbo.Automates Hi Jim. I have three outputs that run a garage remote. An on value is meant to simulate the press of one of the three buttons on the remote. I use programming to run this normally but am trying to set up favorites in UDMobile and found that when I press "on", (at the bottom), the elk output stays on infinitely. I would have expected it to only stay on for the set default value of 2 seconds. Am I missing something?
See screen shot below. When I press the "turn on for" button in the middle it correctly only stays on for 2 seconds. But pressing the on at the bottom of the screen seems to ignore the 2 second setting as the default on seconds.
thanks.
It seems to me this setting is intuitively like a light switch "on" setting: ramp rate + level.  If I set a "default" on value and ramp rate for a light, whenever I turn that light on, that is how it responds. Would think this should act the same way. If I set a default on setting, in this case "seconds", then whenever I turn on that device, I would seem to think that's how it should behave.
Just my opinion...thanks.
