Rename feature question
In new v1.x I see the addition of a configurable option to "rename" nodes when they change in Airthings and wanted to check something.
I ran into a glitch upgrading to v1.0.0 that resulted in all my nodes disappearing from ISY. In all my past dealings with any NS I haven't seen ISY lose nodes even if I uninstall a NS. I've always had to go back and delete the nodes in ISY if I was truly uninstalling something for good.  This time, however, all my nodes were deleted by the upgrade. Is that because of the renaming feature, which I had set to True? Or was it related to one of the confirmed bugs in either v1.0.0 or PG3?
I want to make sure I know the risks involved in enabling that feature. Also, if it is a risk, I'd like to suggest it be mentioned in explanation for this feature on configuration page.
Thanks for putting an update out for this NS.
Solved by Jimbo.Automates
18 minutes ago, Jimbo.Automates said:
The nodes were deleted because you uninstalled the node server. That always deletes the nodes in PG3 and the ISY.
ok I tested this with another NS and it did delete the related ISY nodes. I guess it's been a while since I've deleted a node server. For sure pre-PG3 and maybe even when I was running node servers on separate boxes (not Polisy)
