Can't upgrade Kasa to 3.0.18
I am unable to upgrade from 3.0.16 to 3.0.18.  The only thing I see in the NS log on restart is "WARNING interface:start: No node server version specified. Using deprecated server.json version".  This is in the PG3 log
12/16/2022, 14:17:29 [pg3] info: startNs:: Kasa
12/16/2022, 14:17:29 [pg3] info: startNs:: Kasa is valid
12/16/2022, 14:17:29 [pg3] info: checkLicense:: Kasa Valid perpetual license found.
12/16/2022, 14:17:29 [pg3] info: startNs:: Kasa finished update check
12/16/2022, 14:17:30 [pg3] info: [Kasa(16)] :: Starting Node Server - Version 3.0.16
12/16/2022, 14:17:30 [pg3] info: startNs:: Kasa updating database (enabled, timestarted)
12/16/2022, 14:17:31 [pg3] info: startNs:: Kasa starting polls
12/16/2022, 14:17:31 [pg3] info: Starting Node Server Info timer 0
12/16/2022, 14:17:34 [pg3] info: MQTTS: Client Connected: 00:0d:b9:52:bf:f4_16
12/16/2022, 14:17:37 [pg3] info: [00:0d:b9:52:bf:f4_16] Set notices
12/16/2022, 14:17:37 [pg3] info: node tplkasactl on profile 16 already exists, no nodeDef or driver changes detected
If I try to re-install in stead I get: "Can't find purchase option for license record".  There is a order ID in the purchased servers display so it should be ok to reinstall.
PG3 3.1.15 and IoX 5.4.5
Solved by bpwwer
Your current installation of Kasa is too old to support automatic updates.  The information needed for PG3 to determine what you purchased didn't exist when you did the initial install of Kasa.
You need to either upgrade PG3 to 3.1.16 which will then allow you to re-install from the purchase page or go through the node server store and re-install the node server that way.
In either case, you'll need to select the proper install option and re-install.  A re-install will keep all your current configuration and nodes so you won't lose anything by re-installing.
i did try to re-install through the Node Server store, which is when I received the pop-up about the purchase option.  I'll try the PG3 upgrade and see what happens.
Edit:  Was able to re-install after upgrade to 3.1.16.  Thanks again
Edited by glarsen
