Automatic shut off
How would I set up items to turn off at a certain time of day?
Hello Dodger,
Here is one approach which turns off a lamp at 12:00:01AM if the status of the lamp is anything other than off.
Make a new program using the 'If' and 'Then' part of the program. Once you have finished, save the program and then make sure you enable it by ticking the 'enabled' box, There seems to be a bug in beta version 2.7.12 at the moment that requires you to deselect that box, save and reselect it and save again. If you don't see a little red symbol against the name of the program then you know the program is enabled.
Status 'Living Rm LL - Taliesin Lamp' is not off
And Time is 12:00:01AM
Set 'Living Rm LL - Taliesin Lamp' Off
Regards,
Wayne
ps. you can also use scenes to do this by turning off the scene at the required time.
