eisy pg3 connection
I'm going from 994 to eisy so I am new to this.  I've set up a couple node servers so far, but I cannot seem to get this one to connect.
I should add that I have been using DSCLink for years, but excited about running this on eisy.
I have populated hostname, password and usercode but cannot get it to connect.
I can see it "installed" on eisy, but in PG3 the status is disconnected.
Below is the log after hitting "restart"
12/29/2022, 20:34:34 [pg3] info: [] Retrieved customparams 12/29/2022, 20:34:34 [pg3] info: [] Retrieved customtypeddata 12/29/2022, 20:34:34 [pg3] info: [] Retrieved oauth 12/29/2022, 20:34:56 [pg3] info: Starting log stream for pg3frontend_VPABX :: /var/polyglot/pg3/logs/pg3-current.log 12/29/2022, 20:35:24 [pg3] warn: stopLogging: unwatch failed, TypeError: Cannot read properties of undefined (reading 'pg3frontend_VPABX') 12/29/2022, 20:35:27 [pg3] info: [] Retrieved customparams 12/29/2022, 20:35:27 [pg3] info: [] Retrieved customtypeddata 12/29/2022, 20:35:27 [pg3] info: [] Retrieved oauth 12/29/2022, 20:35:28 [pg3] info: [EnvisaLink-DSC(1)]: Restarting Node Server 12/29/2022, 20:35:28 [pg3] info: [EnvisaLink-DSC(1)]: Stopping Node Server 12/29/2022, 20:35:28 [pg3] info: Making reqeust to socket for /rest/pg3.stop.ns
12/29/2022, 20:35:30 [pg3] info: Starting log stream for pg3frontend_VPABX :: /var/polyglot/pg3/logs/pg3-current.log
12/29/2022, 20:35:32 [pg3] info: startNs:: EnvisaLink-DSC
12/29/2022, 20:35:32 [pg3] info: startNs:: EnvisaLink-DSC is valid
12/29/2022, 20:35:32 [pg3] info: checkLicense:: EnvisaLink-DSC Valid perpetual license found.
12/29/2022, 20:35:32 [pg3] info: startNs:: EnvisaLink-DSC finished update check
12/29/2022, 20:35:32 [pg3] info: Making reqeust to socket for /rest/pg3.start.ns
12/29/2022, 20:35:32 [pg3] info: startNs:: EnvisaLink-DSC starting polls
12/29/2022, 20:35:32 [pg3] info: Starting Node Server Info timer 0
12/29/2022, 20:35:32 [pg3] info: startNs:: EnvisaLink-DSC updating database (enabled, timestarted)
Solved by TSinclair
