What does this mean? "Link for responder 4E CC 5A 1 not found"
In my IoX log, there is this series of events every time I turn on or off several scenes that include all of these Insteon dimmers.
The scenes still work. I have a ticket open with Michel, however with all the transition to 5.5 and eisy introduction issues, I am looking to see if anyone else can help, so as to take something off of Michel and the team's plate.
Here is what shows up in the event viewer:
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 2A 1A 69 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 45 92 AB 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3D F4 6 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 1A 24 15 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 1C 7E A5 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3B 2B 63 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C D7 ED 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C FA D1 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3E E 7D 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3E 1 E7 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3D F0 B3 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 45 8D D3 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 45 91 38 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3D F2 C0 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3D F5 C2 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C F4 64 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 59 1 76 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 4E D6 98 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 40 5C 1E 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3E 1 35 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3D E 13 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 4E CC 5A 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 24 E5 F6 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C 44 1A 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C E3 D5 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C D7 39 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3C E5 5D 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3B C5 E 1 not found
Sat 12/24/2022 06:46:08 PM : [LINK-INFO ] Link for responder 3B CC A7 1 not found
Here is a brief history of recent events:
-Installed the ZMatter board as instructed. Am running 5.4.5 with Zooz 700 dongle. Have NOT update to 5.5 yet.
-Everything was good for 2 -3 days
-Then nothing worked, AC would not connect to any device, PLM said "not connected"
-I assumed PLM went bad and installed a new one through Restore PLM methodology
-Had trouble connecting all day. Would get stuck on subscription services, or not connect at all. Sometimes UD mobile would connect other times it would not. Same with portal web access. Same error on all platforms. Unplugged Polisy ~5x over the next 24-48 hours to get everything working.
-However through SSH, I could see that IoX was running and node servers were up etc, just couldn't connect.
-All was good for about 4 days, then one day all my Zwave devices stopped working. AC said zwave dongle not working.
-Unplugged polisy again and upon reboot all was fine.
-Then I found those lines in the IoX log. I dont know how long they were there. Nor do I know if the original PLM actually was bad or not.
Any thoughts anyone?  Thanks!
Update. IoX just crashed. Cant access it. PG3 is still running however. will be unplugging again. Actually sent sudo service isy start via SSH and it restarted. error log attached.
Crashed happened around 105ISY Error Log.v5.4.5__Fri 2022.12.30 01.33.14 PM.txtpm
Edited by dbwarner5
