Difference between adding or removing a Device
Hello all:
I asked Michel the following question, and I've included his reply.
Hello Michel:
It seems as though "removing" an Insteon switch or KPL button from a scene (group) is a much more rapid process that adding it. Am I imagining this, or is this really the case?
If this is really so, why would there be a difference? Wouldn't changing a link table require just as much time removing something as adding it.?
Hi Frank!
Yes, removing from scene is much faster than adding to a scene. The reason is this:
Each link record is 8 bytes the first one of which is a flag which describes the role of this link A2 (master), E2 (slave), and 22 (not used)
Adding devices into a scene scans the db and finds the first e2, and writes the whole 8 bytes for every linked device
Removing devices from a scene, scans the db for the link record for that specific scene, updates the first byte to 22, and moves the high watermark
In short for adding to a scene, we have to write 8 bytes, for removing we just update 1 byte and high water mark so you should see an approximately 4 time speed difference between the two operations.
UDI Tech Support
More information: http://forum.universal-devices.com
Sent by: Michel Kohanim
Link to comment
Share on other sites
  • 1 month later...
      36.8k
      369.9k
