ELK Node Server installation on new EISY failing - Need help
I am trying to install the V3.5.5 ELK Node server on my new EISY and I getting the following error message:
Node Server install of undefined failed with message: status is not defined
Version information:
PG3x Version 3.1.16
Status: Connected
Frontend Version: 3.1.16
ISY Version: 5.5.2   Connected
I need help resolving the issue.
Also, I tried accessing the configuration help link listed in the readme (https://github.com/UniversalDevicesInc-PG3/udi-poly-ELK/blob/master/POLYGLOT_CONFIG.md) but I got a 404 error with the following message:  The 'UniversalDevicesInc-PG3/udi-poly-ELK' repository doesn't contain the 'POLYGLOT_CONFIG.md' path in 'master'.
Edited by k7zpj
Solved by k7zpj
Upgrading the node server to PG3x Version 3.1.17 resolved the installation error and the node server successfully installed.
