Hello,
I'm having trouble with the add a Z-Wave device popup not appearing.
For F/W & H/W detail please see about_myisy.PNG (attached).
I'm able to view the remove a z-wave device popup.  Please see RemoveDevice_Dialog_Events.PNG (attached).
It seems that when adding a Z-Wave device, there's no popup dialog and the process closes out in 5 seconds.  Please see IncludeDevice_NoDialog_Events.PNG (attached).
I've attempted the suggested troubleshooting: "
I've confirmed Java exceptions as cited here: https://wiki.universal-devices.com/index.php?title=Main_Page#Troubleshooting.  Please see java_settings.PNG (attached).
Thank you UDI!!!
Edited by JKarlan
Obscured IP & uuid
52 minutes ago, JKarlan said:
Hello,
Thank you UDI!!!
I suggest that you do not publish your UUID as could allows others to access your system.
