shbatm Posted January 15, 2023 Author Share Posted January 15, 2023 @Mecheng70 I'm very conscious of the venue I'm in; but if you're already using Home Assistant--you may want to check out Z-Wave JS with a Zooz stick. Link to comment
Mecheng70 Posted January 15, 2023 Share Posted January 15, 2023 3 minutes ago, shbatm said: @Mecheng70 I'm very conscious of the venue I'm in; but if you're already using Home Assistant--you may want to check out Z-Wave JS with a Zooz stick. I tried it with the aeotec stick and it had nothing but issues. I like having the ISY as the controller as my HA in on my media server as a docker. Link to comment
asbril Posted January 15, 2023 Share Posted January 15, 2023 43 minutes ago, Mecheng70 said: I am now at 2 inovelli devices not able to be investigated. So far, 4 hours today to get to about 90% complete. Have you tried exclude and include ? Link to comment
Mecheng70 Posted January 15, 2023 Share Posted January 15, 2023 I did end up doing that... since it was only the two of them, I figured I only have to update two on HA. Link to comment
shbatm Posted January 15, 2023 Author Share Posted January 15, 2023 (edited) Updated list of changes coming 2022.2.0 (bold=New feature) Add Insteon backlight control support to ISY994, bump PyISY to 3.1.7#85981 @MrBill Deprecate isy994.cleanup_entities service (#85931) Add enable switch for ISY994 devices, support availability (#85928) Add Insteon ramp rate select entities to ISY994 (#85895) Bump PyISY to 3.1.5 and fix bad Z-Wave properties from eisy (#85900) (may be pulled into 2023.1.x) Add On Level number entities to ISY994 Insteon Devices (#85798) Deprecate YAML configuration for ISY994 (#85797) Bump PyISY to 3.1.4 to fix dependency issues (#85825) Make use of str.removeprefix and .removesuffix (#85584) Move ISY994 data to dataclass and remove bad entities (#85744) Consolidate device info and clean-up ISY994 code base (#85657) Remove old migrate unique ID code from ISY994 (#85641) Add ISY994 variables as number entities (#85511) Add network resource button entities to ISY994 and bump PyISY to 3.0.12 (#85429) Add beep button entity to ISY994 Insteon devices (#85367) Add query button entities to ISY994 devices and hub (#85337) Use Platform enum and remove DOMAIN as X imports in ISY994 (#85341) Add additional device classes to ISY994 sensors and bump PyISY to 3.0.11 (#85315) Add additional device classes and units to ISY994 aux sensors (#85274) Restore low battery state on ISY994 Insteon heartbeat nodes (#85209) Assign ISY994 program entities to hub device, simplify device info (#85224) ISY994: Add dhcp support for eisy (#85083) Update ISY994 integration to be model agnostic (#85017) Change ISY994 group device assignments (#84933) Edited January 16, 2023 by shbatm 2 Link to comment
Mecheng70 Posted January 15, 2023 Share Posted January 15, 2023 Question for you on state and integer variables. They are not coming over. Did something change? At one point the type and number needed to be in the configuration.yaml. Link to comment
shbatm Posted January 15, 2023 Author Share Posted January 15, 2023 (edited) Until 2023.2.0, you have to set the variable string in the config options to get them to show up as sensors Settings > Devices & Services > Integrations tab Click configure under Universal Devices ISY994 Next month they'll all come in as number entities. The only thing that setting will control is which get enabled by default. Sent from my SM-S908U using Tapatalk Edited January 15, 2023 by shbatm Link to comment
Mecheng70 Posted January 15, 2023 Share Posted January 15, 2023 5 minutes ago, shbatm said: Until 2023.2.0, you have to set the variable string in the config options to get them to show up as sensors Settings > Devices & Services > Integrations tab Click configure under Universal Devices ISY994 Next month they'll all come in as number entities. Sent from my SM-S908U using Tapatalk And this is what happens when you don't touch something for so long. THANK YOU! Link to comment
shbatm Posted January 16, 2023 Author Share Posted January 16, 2023 Screenshots of changes: Variables: Network Resources: 2 Link to comment
Mecheng70 Posted January 16, 2023 Share Posted January 16, 2023 Will aeotec light bulbs have a color wheel? For locks, will there be a way to update lock passwords? One thing I have been struggling is updating the led status on the switches. I can do it from the ISY, but the set parameter doesn't seem to work well if at all. Link to comment
MrBill Posted January 16, 2023 Share Posted January 16, 2023 30 minutes ago, shbatm said: Screenshots of changes: looks amazing! above and beyond any expectation I ever had for the UD integration! Many Thanks! Link to comment
Mecheng70 Posted January 16, 2023 Share Posted January 16, 2023 Just now, MrBill said: looks amazing! above and beyond any expectation I ever had for the UD integration! Many Thanks! Completely agree. Link to comment
shbatm Posted January 16, 2023 Author Share Posted January 16, 2023 25 minutes ago, Mecheng70 said: Will aeotec light bulbs have a color wheel? For locks, will there be a way to update lock passwords? One thing I have been struggling is updating the led status on the switches. These updates are mostly aimed at Insteon devices. I am working on the logic for pulling in Node Server Profiles which will enable advanced sorting and identification of available controls. After that's finished, it can be easily back-ported to handle the more advanced entities for Z-Wave. I don't use Z-Wave on the ISY, so it's been my lowest priority (sorry, honest truth with limited time). If you'd like to help you can provide your core node def files since I don't have any: http://polisy.local:8080/rest/profiles/download/core -> save as core.zip http://polisy.local:8080/rest/zwave/node/0/def/get -> save as node_def_zwave.xml Link to comment
Mecheng70 Posted January 16, 2023 Share Posted January 16, 2023 6 minutes ago, shbatm said: http://polisy.local:8080/rest/profiles/download/core -> save as core.zip http://polisy.local:8080/rest/zwave/node/0/def/get -> save as node_def_zwave.xml First one for the core.zip worked. The second URL errors out. core.zip Link to comment
Mecheng70 Posted January 16, 2023 Share Posted January 16, 2023 8 minutes ago, shbatm said: http://polisy.local:8080/rest/zwave/node/0/def/get -> save as node_def_zwave.xml http://172.16.5.251:8080/rest/zwave/node/0/def/get -> results in This page isn’t working 172.16.5.251 didn’t send any data. ERR_EMPTY_RESPONSE Link to comment
shbatm Posted January 16, 2023 Author Share Posted January 16, 2023 Are you using Z-Wave or Z-Matter? I'll have to play around and see if I can figure out what the address is supposed to be. That looks right per the Wiki. Link to comment
Mecheng70 Posted January 16, 2023 Share Posted January 16, 2023 2 minutes ago, shbatm said: Are you using Z-Wave or Z-Matter? I'll have to play around and see if I can figure out what the address is supposed to be. That looks right per the Wiki. I have the new zmatter dongle on the eisy. And I double checked the ISY Cookbook to make sure I didn't mess it out. Link to comment
shbatm Posted January 18, 2023 Author Share Posted January 18, 2023 Closing the loop on discussion in the PMs: The url for ZMatter has changed to /rest/zmatter/zwave 1 Link to comment
asbril Posted January 18, 2023 Share Posted January 18, 2023 @shbatm Any update on ETA of patch to resolve issues between eisy and HA ? Link to comment
shbatm Posted January 18, 2023 Author Share Posted January 18, 2023 (edited) The changes are merged, but unfortunately there are already too many other changes in PyISY for this to be picked up in a January update. They will be released in 2022.2.0. You can: 1. Wait until Feb ~5th for the stable release 2. Wait until late Jan for the beta (and choose use beta channel) 3. Install now by using the dev channel. If you install the dev channel you will also be able to preview and test the new features. Edited January 18, 2023 by shbatm 1 Link to comment
Mecheng70 Posted January 18, 2023 Share Posted January 18, 2023 I am still struggling with programs not running on HA that control the eisy. Honestly think that it is the eisy. It becomes unresponsive several times a day. For instance, my program that turns on the simplisafe and internal cameras, did not turn off the living room and kitchen lights. Last night, I was trying to program the door locks from the rest command and getting a 404 error. Then the locks would disappear. I was able to reprogram the locks through AC, but then had to reboot the eisy. I reboot that thing 2-3x a day!!!! Link to comment
MrBill Posted January 18, 2023 Share Posted January 18, 2023 @Mecheng70 does the ISY error log give any clues what's happening? Link to comment
Mecheng70 Posted January 18, 2023 Share Posted January 18, 2023 3 minutes ago, MrBill said: @Mecheng70 does the ISY error log give any clues what's happening? I have a ticket open. But me personally, I do not have a clue... ISY-Error-Log.v5.5.3__Tue-2023.01.17-18.03.32.txt Link to comment
MrBill Posted January 18, 2023 Share Posted January 18, 2023 3 minutes ago, Mecheng70 said: I have a ticket open. But me personally, I do not have a clue... wow... that's much different than the isy994 error logs that I'm only half good at deciphering... looks like errors, but i don't know what they mean either. Link to comment
asbril Posted January 18, 2023 Share Posted January 18, 2023 1 hour ago, Mecheng70 said: I am still struggling with programs not running on HA that control the eisy. Honestly think that it is the eisy. It becomes unresponsive several times a day. For instance, my program that turns on the simplisafe and internal cameras, did not turn off the living room and kitchen lights. Last night, I was trying to program the door locks from the rest command and getting a 404 error. Then the locks would disappear. I was able to reprogram the locks through AC, but then had to reboot the eisy. I reboot that thing 2-3x a day!!!! Since migration I don't get anything from eisy on HA. Before migration I had a few (ZWave) devices on ZMatter on eisy and they were working fine in HA. Now the integration just does not work at all. @shbatmidentified the issue and hopefully this should be adressed in a February upgrade of the ISY integration. Link to comment
