Program turning on a scene problem
hbdude
Go to solution Solved by MrBill,
I have installed my new eisy. I did not try to import my old programming. I wanted to start out fresh. I have a scene that turns on several switches. I turn this scene on with a program and it turns on the switches in the scene one switch that is not in the scene. I am wondering if I can find out what is turning this switch on
For all the switches in the scene and the one that's not right click them in the device tree and choose "Restore Device", do them one at a time and wait until the ISY is finished before moving on to the next.
When you started out fresh did you do it by factory resetting the PLM and each device then adding it to the eisy?
No I used my old PLM. Just unplugged it from my ISY-994 and plugged it into the Eisy. That fixed it. Is there any reason to factory reset the PLM?
Thanks for your help
      37.6k
      376.3k
