MyQ Will not start after attempt to update to v3.1.21 on Polisy
Hello @Goose66, after attempting to upgrade MyQ to .21 it shows as disconnected. Further restarting either the MyQ node server or PG3 results in disconnected and it still shows an upgrade is available. No logging after the upgrade.
I am on Polisy with PG3 v3.1.16 and IoP on v5.5., currently MyQ reports v3.1.19
If you would like a log file from PG3 please let me know to send please.
Any suggestions would be appreciated.
Solved by TJF1960
Update:
Deleting and re-installing the node service back into the same slot fixed the issue.
@TJF1960 If it's not too late I would still like to get a log package from you, including the node server log (which may be gone) and the PG3 log so that I can understand what went wrong. Version 3.1.21 was released to fix the same, specific symptoms you described which were happening in 3.1.20.
@Goose66, The file size is 2.6mb, I waited 20 minutes and it still wasn't uploaded, perhaps the forum will not allow attachments that large?  Is there somewhere else I can send it to?
