Reload ISY integration variables run in the opposite state.
Posted (edited)
@MrBillor anyone that know the answer.
Every time I reload the ISY integration any automations I have based on ISY variables seem to run if they are in the opposite state.  Like if a roller shade closes when HA.Kitchen.Roller.Shades = 0 then if I reload the integration because I have changes I need HA to see then the shades close if they are open because they see change even though that variable in the ISY did not really change.  Same for switches I have made in the ISY using the HA.switch folder with sub folders for switches.
I don't keep track of roller shade position since someone might open or close them with the RF remote and then the state is wrong anyway.  I just send a 1 and then 0 to close them and a 0 and then a 1 to open them.
I guess I could use two variables so the 0 value never runs anything but that's just more to have to remember why I did things the way I did.
Thank you!
Edited by btreinders
I'm not sure why, without more information but my guess is that HA is detecting the variable change from unknown to zero.
A better approach is one that I use with my overhead barn door...
The ISY variable is normal value is zero.  When ISY wants to open a door, the value is changed to 1, the HA Automation then opens the door and calls the service isy994.set_variable to change the isy variable back to zero.  When the value of the variable is changed to -1 then HA closes the door and again calls isy994.set_variable to change the ISY variable back to zero.
With that method zero is a neutral value, nothing happens when the variable assumes that value.
Whenever I get around to migrating to eisy that automation will change, I couldn't figure out how to read an Insteon button back when i created that, but it's likely a good solution for your shade.
  • Like 1
      37.3k
      373.6k
