IoX Release v5.5.4 - OUTDATED
* IoX = ISY on Anything.
Welcome to ZMatter Z-Wave+ Beta !
In this build we focused on fixing issues with device interviews and device support along with a few other bugs.
    Getting Started
    • Make a backup of Polisy (Admin Console | File | Backup IoX )
    • Launch the Admin Console, go to the Configuration tab, click on Update Packages. Warning, this might take a while depending on how current your OS is
    • Once completed (4 beeps + 1), unplug Polisy
    • If you are using INSTEON, make sure the PLM is connected
    • Power up your Polisy note that initial boot might take a much longer time than normal because udx might want to install missing packages to assist with migration (in the future)
    • Once boot up is complete, Launch Admin Console
    Migrating to ZMatter Z-Wave+
    • Go to the configuration tab and press the Migrate to ZMatter Z-Wave button to start migration
    • Please pay close attention to the instructions
    • Do not unplug or install any Z-Wave boards / dongles until instructed to do so during migration
    • When IoX restarts for the first time during migration, you will see that your old Z-Wave nodes are not enabled.  As the device interviews proceed, they will become enabled as they are updated with data from the new Z-Wave implementation.
    • The best way to monitor the progress is to open the Admin Console Event Viewer to level 3
    • For those who want lots of low-level details, you can also use this from the command line: tail -f /var/isy/FILES/LOG/ZWAY.LOG
    • Note: The only way to go back to the original Z-Wave implementation is to restore a backup that was made prior to moving to ZMatter Z-Wave+
         Here are the installation instructions for those of you with a ZMatter Z-Wave board (not USB dongle):
    Features
    • Support non-secure inclusion
    Bug Fixes
    • Some interviews fail or only partially complete due to communication problems
    • ZMatter Z-Wave port detection (no more need for manual override)
    • ZEN16 support (due to ZEN16 device limitations, it must be included non-secure)
    • Cannot add some Schlage locks
    • Motion sensor does goes on but not off
    • Remove 2nd option for ZMatter Z-Wave migration
    • Long "system busy" at startup after migration
    • Show ZMatter Z-Wave Connected/Not Connected in Admin Console
    • Show ZMatter Z-Wave Detect button press active or not
    • @WEBPAGE in Notifications
