Cannot set a variable from node server Wind direction (WINDDIR)
Hello,
I am trying to copy the wind direction (WINDDIR) to a variable but it doesn't work.  I checked the XML files in the ISY backup and it doesn't match the node server UOM of 76, the backup file has it at 14.  I think the UOM for wind direction should be 76 instead of 14, see below.
<editor id="I_DEGREES">
        <range uom="14" min="-360" max="360" prec="0" />
Thanks again for the assistance.
Solved by bpwwer
