Can't discover denon or LG TV
I'm first trying to get AVremote working on my Eisy w PG3 to a Denon AVR and an LG TV and getting the error that the DISCOVER command is not defined. Any ideas?.
2023-02-04 15:23:49,493 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down.
2023-02-04 15:23:53,737 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30
2023-02-04 15:23:54,097 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.51 Starting...
2023-02-04 15:23:54,400 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.1.22 [ISY: 5.5.5, Slot: 13]
2023-02-04 15:23:54,400 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '10.10.1.171', 'netmask': '255.255.255.0', 'broadcast': '10.10.1.255'}
2023-02-04 15:23:54,400 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2023-02-04 15:23:54,401 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version
2023-02-04 15:23:54,401 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL certs: 0021b9026068_13.cert 0021b9026068_13.key
2023-02-04 15:23:54,402 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: controller not found in database.
2023-02-04 15:23:54,402 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'config': {'version': '1.0.1'}}
2023-02-04 15:23:54,409 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success)
2023-02-04 15:23:54,409 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:60:68_13 - MID: 2 Result: 0
2023-02-04 15:23:54,452 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2023-02-04 15:23:57,513 MainThread udi_interface.interface INFO interface:addNode: Adding node AVRemote(controller) [None]
2023-02-04 15:23:57,513 MainThread udi_interface.interface INFO interface:setController: Using node "controller", driver "ST" for connection status.
2023-02-04 15:23:57,556 Thread-1 udi_interface INFO remotecontroller:handle_level_change: AVRemote New log level: {'name': 'INFO', 'level': 20}
2023-02-04 15:23:57,598 Thread-3 udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot.
2023-02-04 15:23:57,599 Thread-3 udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot.
2023-02-04 15:23:57,613 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata
2023-02-04 15:23:57,681 Thread-3 udi_interface INFO remotecontroller:handler_custom_typed_data: Regenerating profile
2023-02-04 15:23:57,698 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata
2023-02-04 15:23:57,699 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata
2023-02-04 15:23:57,704 Thread-3 udi_interface INFO remotecontroller:handler_custom_typed_data: Profile not changed. Skipping
2023-02-04 15:23:57,704 Thread-3 udi_interface INFO remotecontroller:createDevices: Creating Devices...
2023-02-04 15:23:57,705 Thread-3 udi_interface INFO web_os:__init__: Needs device registration acceptance
2023-02-04 15:23:57,705 Thread-3 udi_interface INFO web_os:__init__: Loaded WebOS driver
2023-02-04 15:23:57,705 Thread-3 udi_interface INFO remotecontroller:createDevices: OLED65C9PUA
2023-02-04 15:23:57,706 Thread-3 udi_interface.interface INFO interface:addNode: Adding node OLED65C9PUA(d_0) [None]
2023-02-04 15:23:57,706 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Audio(d_1) [None]
2023-02-04 15:23:57,706 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Basic Media(d_2) [None]
2023-02-04 15:23:57,707 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Inputs(d_3) [None]
2023-02-04 15:23:57,707 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Media(d_4) [None]
2023-02-04 15:23:57,708 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Navigation(d_5) [None]
2023-02-04 15:23:57,708 Thread-3 udi_interface INFO denon_avr:__init__: Loaded DenonAVR driver
2023-02-04 15:23:57,709 Thread-3 udi_interface INFO remotecontroller:createDevices: AVR
2023-02-04 15:23:57,709 Thread-3 udi_interface.interface INFO interface:addNode: Adding node AVR(d_6) [None]
2023-02-04 15:23:57,709 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Zone2(d_7) [None]
2023-02-04 15:23:57,710 Thread-3 udi_interface.interface INFO interface:addNode: Adding node Zone3(d_8) [None]
2023-02-04 15:23:57,795 Thread-9 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2023-02-04 15:23:57,795 Thread-9 udi_interface INFO remotecontroller:handler_start: Starting AVRemote Node Server
2023-02-04 15:23:57,796 Thread-9 udi_interface INFO remotecontroller:handler_start: AVRemote Node Server Version 1.0.1
2023-02-04 15:23:57,796 Thread-9 udi_interface.custom INFO custom:_save: Sending data customtypedparams to Polyglot.
2023-02-04 15:23:57,812 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2023-02-04 15:23:57,825 MainThread udi_interface INFO remotecontroller:createDevices: Creating Devices...
2023-02-04 15:23:57,828 MainThread udi_interface INFO remotecontroller:createDevices: OLED65C9PUA
2023-02-04 15:23:57,828 MainThread udi_interface.interface INFO interface:addNode: Adding node OLED65C9PUA(d_0) [None]
2023-02-04 15:23:57,829 MainThread udi_interface.interface INFO interface:addNode: Adding node Audio(d_1) [None]
2023-02-04 15:23:57,830 MainThread udi_interface.interface INFO interface:addNode: Adding node Basic Media(d_2) [None]
2023-02-04 15:23:57,831 MainThread udi_interface.interface INFO interface:addNode: Adding node Inputs(d_3) [None]
2023-02-04 15:23:57,831 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customtypedparams
2023-02-04 15:23:57,831 MainThread udi_interface.interface INFO interface:addNode: Adding node Media(d_4) [None]
2023-02-04 15:23:57,832 MainThread udi_interface.interface INFO interface:addNode: Adding node Navigation(d_5) [None]
2023-02-04 15:23:57,832 MainThread udi_interface INFO remotecontroller:createDevices: AVR
2023-02-04 15:23:57,832 MainThread udi_interface.interface INFO interface:addNode: Adding node AVR(d_6) [None]
2023-02-04 15:23:57,833 MainThread udi_interface.interface INFO interface:addNode: Adding node Zone2(d_7) [None]
2023-02-04 15:23:57,833 MainThread udi_interface.interface INFO interface:addNode: Adding node Zone3(d_8) [None]
2023-02-04 15:23:59,841 MQTT udi_interface.interface INFO interface:_message: Successfully set controller :: ST to 1 UOM 25
2023-02-04 15:24:01,013 Thread-12 udi_interface WARNING web_os:connect: (64, 'Host is down')
2023-02-04 15:24:02,742 Thread-49 udi_interface ERROR base_driver:start: Connection to AVR:23 failed
Traceback (most recent call last):
File "/var/polyglot/pg3/ns/0021b9026068_13/drivers/base_driver.py", line 24, in start
self.connect()
File "/var/polyglot/pg3/ns/0021b9026068_13/drivers/denon_avr.py", line 37, in connect
self.conn.connect((self.config['hostName'], self.config['port']))
socket.gaierror: [Errno 8] Name does not resolve
self.connect()
2023-02-04 15:24:02,742 Thread-48 udi_interface ERROR base_driver:start: Connection to AVR:23 failed
self.connect()
self.connect()
2023-02-04 15:24:03,197 Thread-72 udi_interface ERROR base_driver:start: Connection to AVR:23 failed
self.connect()
self.connect()
2023-02-04 15:24:03,197 Thread-73 udi_interface ERROR base_driver:start: Connection to AVR:23 failed
self.connect()
self.connect()
2023-02-04 15:24:47,789 Command udi_interface.node ERROR node:runCmd: node controller command DISCOVER not defined
Neither Denon nor LG will auto discover. You need to configure them in configuration page. You will need to put a name and IP address or a host name. Also, this only works with older WebOS LGs, not the newer one. Since I don't have newer one, I can't really support it.
Which "Discover" button did you press? I'll fix the error.
I changed the host name from "AVR" (which is what its called in Unifi) to "192.168.1.50". This made the TV and the AVR controllers show as online but nodes under the AVR node actually pointed to the TV. I deleted the TV configs from the node server configuration and all the nodes in Iox to focus on the AVR. Restarting the node server now shows that it can't find 192.168.1.50. Could port 23 be wrong?
the re-discover button I pushed was in the AVRemote controller node.
2023-02-04 19:17:35,496 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.51 Starting...
2023-02-04 19:17:35,802 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.1.22 [ISY: 5.5.5, Slot: 13]
2023-02-04 19:17:35,803 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '10.10.1.171', 'netmask': '255.255.255.0', 'broadcast': '10.10.1.255'}
2023-02-04 19:17:35,803 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883
2023-02-04 19:17:35,804 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version
2023-02-04 19:17:35,804 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL certs: 0021b9026068_13.cert 0021b9026068_13.key
2023-02-04 19:17:35,804 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: controller not found in database.
2023-02-04 19:17:35,805 MainThread udi_interface.interface WARNING interface:send: MQTT Send waiting on connection :: {'config': {'version': '1.0.1'}}
2023-02-04 19:17:35,811 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success)
2023-02-04 19:17:35,812 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:60:68_13 - MID: 2 Result: 0
2023-02-04 19:17:35,854 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2023-02-04 19:17:38,824 MainThread udi_interface.interface INFO interface:addNode: Adding node AVRemote(controller) [None]
2023-02-04 19:17:38,825 MainThread udi_interface.interface INFO interface:setController: Using node "controller", driver "ST" for connection status.
2023-02-04 19:17:38,867 Thread-1 udi_interface INFO remotecontroller:handle_level_change: AVRemote New log level: {'name': 'INFO', 'level': 20}
2023-02-04 19:17:38,908 Thread-4 udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot.
2023-02-04 19:17:38,909 Thread-4 udi_interface.custom INFO custom:_save: Sending data customdata to Polyglot.
2023-02-04 19:17:38,925 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata
2023-02-04 19:17:38,992 Thread-4 udi_interface INFO remotecontroller:handler_custom_typed_data: Regenerating profile
2023-02-04 19:17:39,009 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata
2023-02-04 19:17:39,011 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customdata
2023-02-04 19:17:39,015 Thread-4 udi_interface INFO remotecontroller:handler_custom_typed_data: Profile not changed. Skipping
2023-02-04 19:17:39,015 Thread-4 udi_interface INFO remotecontroller:createDevices: Creating Devices...
2023-02-04 19:17:39,016 Thread-4 udi_interface INFO denon_avr:__init__: Loaded DenonAVR driver
2023-02-04 19:17:39,016 Thread-4 udi_interface INFO remotecontroller:createDevices: AVR
2023-02-04 19:17:39,016 Thread-4 udi_interface.interface INFO interface:addNode: Adding node AVR(d_0) [None]
2023-02-04 19:17:39,017 Thread-4 udi_interface.interface INFO interface:addNode: Adding node Zone2(d_1) [None]
2023-02-04 19:17:39,017 Thread-4 udi_interface.interface INFO interface:addNode: Adding node Zone3(d_2) [None]
2023-02-04 19:17:39,111 Thread-9 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot.
2023-02-04 19:17:39,111 Thread-9 udi_interface INFO remotecontroller:handler_start: Starting AVRemote Node Server
2023-02-04 19:17:39,112 Thread-9 udi_interface INFO remotecontroller:handler_start: AVRemote Node Server Version 1.0.1
2023-02-04 19:17:39,112 Thread-9 udi_interface.custom INFO custom:_save: Sending data customtypedparams to Polyglot.
2023-02-04 19:17:39,127 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices
2023-02-04 19:17:39,136 MainThread udi_interface INFO remotecontroller:createDevices: Creating Devices...
2023-02-04 19:17:39,137 MainThread udi_interface INFO remotecontroller:createDevices: AVR
2023-02-04 19:17:39,138 MainThread udi_interface.interface INFO interface:addNode: Adding node AVR(d_0) [None]
2023-02-04 19:17:39,138 MainThread udi_interface.interface INFO interface:addNode: Adding node Zone2(d_1) [None]
2023-02-04 19:17:39,139 MainThread udi_interface.interface INFO interface:addNode: Adding node Zone3(d_2) [None]
2023-02-04 19:17:39,146 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customtypedparams
2023-02-04 19:17:39,852 MQTT udi_interface.interface INFO interface:_message: Successfully set controller :: ST to 1 UOM 25
2023-02-04 19:18:37,544 Command udi_interface.node ERROR node:runCmd: node controller command DISCOVER not defined
2023-02-04 19:18:55,660 Thread-12 udi_interface ERROR base_driver:start: Connection to 192.168.1.50:23 failed
self.connect()
TimeoutError: [Errno 60] Operation timed out
2023-02-04 19:18:55,660 Thread-13 udi_interface ERROR base_driver:start: Connection to 192.168.1.50:23 failed
self.connect()
2023-02-04 19:18:55,901 Thread-20 udi_interface ERROR base_driver:start: Connection to 192.168.1.50:23 failed
self.connect()
2023-02-04 19:18:55,902 Thread-21 udi_interface ERROR base_driver:start: Connection to 192.168.1.50:23 failed
self.connect()
2023-02-04 19:19:03,807 Command udi_interface.interface ERROR interface:_handleInput: _parseInput: node address d_6 does not exist. {'address': 'd_6', 'cmd': 'power', 'value': '1', 'uom': '25', 'query': {}}
The name "AVR" needs to resolve properly on polisy/eisy. If you ssh into it and 'ping AVR' or 'nslookup AVR', that will show you if name resolution works. It's a property of your DNS setup.
23 should be correct port. Check receiver settings. There should be settings related to IP control. I think by default it's off when receiver is in standby. But there could be others. You can test it with telnet from any computer.
telnet 192.168.1.50 23
If it's up, you should connect and you can send telnet commands by typing them.
Are you using version from prod store or new version from beta store?
Also, PM logs to me. Easier to look in file format and doesn't pollute the forum.
Edited by firstone
DNS comment
