IoX Release v5.5.6 - OUTDATED
* IoX = ISY on Anything.
Welcome to ZMatter Z-Wave+ Beta v5.5.6 !
Features
  • Z-Wave Compatibility Mode to support non-conforming Z-Wave devices (right+click Z-Wave | Compatibility Mode)
    • Fixes problems with status updates / user codes for many locks
  • Added 'Theme Size' to Admin Console for wider node selection boxes
  • X-Ray for Insteon nodes
Bug Fixes
  • Thermostat F/C now uses preferred measurement system (as specified in configuration tab)
  • Garage Door events not being reported (barrier alarm events)
  • Garage Door status not being updated (barrier operator CC)
  • Cannot add Schlage FE599 door lock
  • Sync / Sync new & deleted now creates nodes even if interview not done / attempted (unless device is being migrated)
  • Occupancy Node Server may be deleted at IoX startup
  • Make "Show Native Links" more readable
  • Show green "writing" icon when writing to Z-Wave devices
Getting Started
  • Make a backup of Polisy (Admin Console | File | Backup IoX )
  • Launch the Admin Console, go to the Configuration tab, click on Update Packages. Warning, this might take a while depending on how current your OS is
  • Once completed (4 beeps + 1), unplug Polisy
  • If you are using INSTEON, make sure the PLM is connected
  • Power up your Polisy note that initial boot might take a much longer time than normal because udx might want to install missing packages to assist with migration (in the future)
  • Once boot up is complete, Launch Admin Console
Migrating to ZMatter Z-Wave+
Here are the installation instructions for those of you with a ZMatter Z-Wave board (not USB dongle):
