Zooz ZSE29 and IoX 5.5.7
There is discussion from myself and others about Zooz ZSE29 in the support thread for IoX 5.5.7 release. I have a ticket open, and thought I would open a new thread and give an update:
My ZSE29 is hardware version 1.0  At the suggestion of UD, I did more testing, and confirmed the following:
* Wake-up does not occur due to motion detection. Wake-up occurs at power-on, and at the wake-up interval, which is set by default to 4 hours. Once woken up, the device stays awake for 10 seconds. The wake up interval value does not appear to be configurable in any way. There is no difference in behavior for battery powered vs continuous DC power supply.
I did a test where I initiated a write changes from the AC immediately after having applied power to the ZSE29. The writes did complete for this scenario, as evidenced by the green 1011 icons in the AC going away after just a few seconds.
Even with the default wake up interval of 4 hours, the write changes should have been written at the first wake up event. UD is continuing to investigate why IoX code is not performing the write when the wake up happens.
